Originally Posted by josh9mille
no i dont have a volt meter. the batteries read about 6.32 volts when i hooked them to my charger but that was about 30 minutes after i stopped running them so i think the voltage probably came back up a bit just from sitting.
If the resting voltage came back up to 6.32 volts, there shouldn't be any harm done.
They should be ok.
Balancing is always a good practice. Is your charger a balance charger or do you have a separate balancer?
I would check the balance on them when they are nearly charged again.
