Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
CC Blower now on sale!
Joe Ford
Castle's Chaos Corner
Joe Ford's Avatar
CC Blower now on sale! - 09.16.2009, 09:21 PM
http://www.castlecreations.com/products/cc_blower.html
Cooling for your 2200kv or 2650kv Castle-Neu motor!
Joe Ford
Product Specialist
Foxracin
09.16.2009, 09:24 PM
Is the fan supposed to be better quality the the fan on the MMM? Looks pretty good on paper
09.16.2009, 09:31 PM
Brian's New Avatar...
09.17.2009, 12:22 AM
Har har.
fastbaja5b
fastbaja5b's Avatar
Will there be one to fit the HPI Flux (CC) Motors with that larger heatsink in the middle of the can?
Say Less, Do More.
Rivermaxx
09.16.2009, 11:31 PM
How do you recommend we hook it up joe?
sikeston34m
sikeston34m's Avatar
09.16.2009, 11:32 PM
The blower plugs into the receiver. Pretty Simple
Rivermaxx
09.16.2009, 11:36 PM
You can turn it on and off with a third channel?
sikeston34m
09.16.2009, 11:39 PM
I would think not, but correct me if I'm wrong here guys.
The three pins in the receiver socket are:
Negative
Positive
PWM Channel - Pulse Width Modulation
I'm sure the blower only picks up the Negative and Positive Pins.
If it's plugged in, it's gonna run.
Rivermaxx
09.16.2009, 11:43 PM
I know there is a switch that makes it so you can turn the third channel on and off like a light switch.
MetalMan
MetalMan's Avatar
09.17.2009, 02:22 AM
The 3rd channel will do that with a servo or any other device designed to operate on 1-2ms pulses. But so long as the fan is plugged in and the receiver has power applied to it the fan will blow, regardless of the 3rd channel (or any channel for that matter).
webracer
webracer's Avatar
10.19.2009, 02:56 PM
I think you could try a battleswitch (www.dimensionengineering.com). We use it on RC planes and helis to launch bottle rockets and such. Problem is you need a separate power source for the fan (maybe another open slot (like the bind/batt slot on Spektrum) to power the fan).
Troy
I am now free to exercise my downward mobility
rchippie
rchippie's Avatar
10.26.2009, 03:27 PM
I just orderd the castle blower for my ERT . My temps are fine with out it . But a little cooler never hurts electric componets .
REAL MEN RUN BRUSHLESS
rchippie
rchippie's Avatar
11.02.2009, 03:44 PM
My blower showed up today, It looks pretty cool . Im going to order a couple of 30mm fans for spares . I also shortend the wires off the fan & ran a servo extention cable . So i can just plug the fan in on the side on my MMM, with out having to route the plug all the way to the reciver. This will make it alot eaiser when i have to replace the fan .
ID:	7925   Click image for larger version
Dadx2mj
Dadx2mj's Avatar
09.17.2009, 12:48 AM
That just looks like it is meant to be to me.
Blindman Racing
Powered by Mamba 5700
