MMpro & 60mm medusa in a 1/8 Truggy? -
04.06.2010, 09:27 AM
I have a 1/8 Mutilator Truggy, MMPro, and a 60mm1300kv medusa. I'm thinking about putting the electronics in the Mutilator and gear for 20mph on 5s or 25mph on 6s. The truck would be for a kid, so it doesn't have to go any faster.
Do you think the esc&motor will work(not overheat) in this setup?
Yeah, amp draw should be pretty low. I would also set the punch control way up, like 100%. Should tame the wheelies!!! Or front tire unloading depending on what thickness center diff fluid you use.
that combo is perfect for what you are wanting to do.
