Originally Posted by BP-Revo
I've noticed that the slipperential housing (the threaded part which also has the grooves that the spider gear shafts key into) has many little veins/slots.
Considering the OP had to cut down one of the spider gear shafts, is it possible that he keyed the spider gear shafts into the wrong slot - thus causing binding?
Na, the cross pin for the large spider was a touch long so I just took off .080'ish from it. So it's not the small spider cross pin/pins. They are all properly located within the diff housing....
Mike,
I did pull the gasket and it did seem to feel a little better so might be a touch on the loose side possibly. That being said, one would assume the addition of the o-rings behind the small spiders would decrease the clearance between the small/large spiders and it "should" have gotten better/smoother. Thus far, that hasn't been the case.
Like I said, I got it pretty well sorted. I'm going to run it a touch and see if things smooth out some. I've built a million (maybe not a million but significant) 1/8th scale diffs and this isn't any different from an assembly standpoint. Just seems there a little something going on in there clearance wise.
Stay Tuned -
