Associated TC5-R build
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
Associated TC5-R build - 07.25.2010, 12:25 PM
Just finished the build, I love kits. I wished more Co's would do kits and they don't always have to be the higher end stuff either. I't would be great to buy a Slash or somthing in kit form, save some money and experience the complexities of these awesome little cars/trucks.
As usual, AE build instructions are pretty good. I had only a couple small problems and they were easily remedied by rereading the instructions a few times.
Here's the shocks, they are redesigned for the TC5. Personally, I think the TC4 style are better and def easier to build. They are designed with a "rebound foam", one disc goes into the bladder and a small barrel shaped one inside the cap. It was next to impossible to get all that in the shock and not have air bubbles or spill oil all over. A quick reference to the option/set-up sheet I found these were left out for my application, so I was very happy to see that because they are a PITA !
The diffs were very easy to assemble, typical ball diff for AE nothing new here. The front one was intended as a spool so assembly was even easier due to no ball bearings but with a white pad made of some sort of plastic and locked down tight.
CVD's were a cinch also, AE has a spring steel clip/band that covers the pins. So if the grub screw comes loose the pin will not be ejected.
Everyones favorite thing, *$%#@ Turnbuckles
Bell crank steering assembly. Doesn't look like much, but when the car is together and this in sandwiched between the lower and upper plate it's stout and is very smooth.
The Carbon/Graphite chassis pieces and towers. Very High qaulity looking stuff.
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
07.25.2010, 01:03 PM
I've been wanting to build one of these... so I'll be watching this thread and asking a lot of questions
Alien
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.25.2010, 01:04 PM
A wounderful sight, numbered bag with lots of little parts.
Heres the arms assembled ans awaiting the bulkheads
All the parts laid out, the fit and finish of the aluminum parts is top notch.
Heres the four corners assembled ready to be added on.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.25.2010, 01:18 PM
With it being a Little TC and space being in short supply I decided to shorten all the wires.
It takes guts to open and solder wires on a new $80.00 servo. One thing I noticed that I didn't like with this Spektrum Servo is that were the wires are soldered to the board is more inside the servo instead of being more accesable like the JR's. So rather than desoldering the wires form the board I chose to cut then instead. Not as neat as I would have liked but it suites the purpose.
I decided to mount the RX on top of the servo and made a antenna mount.
Shortened wire for the MMPro also.
100% complete chassis
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.25.2010, 01:20 PM
Heres everything intalled, I still have to align all 4 tires yet and test drive it. Maybe later today after HoneyDoo's. My first Oval race is Monday night and I have yet to receive the body I ordered from RC-Boys, I guess I'll have to use what I have on hand ?
ANGRY-ALIEN
07.25.2010, 01:36 PM
Nice... a very clean build... what's the final weight of that setup with batts?
slimthelineman
slimthelineman's Avatar
07.25.2010, 01:41 PM
looks good man! tc is a lot of fun. i see you have an invaluble tool for assembly many also use lurking in a photo up there! lol
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.25.2010, 01:45 PM
NO body, with a 5000mah 2s Turnigy 30C lipo 2lbs 12.6ozs
I never noticed till you mentioned it, Doh!
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.25.2010, 01:48 PM
In case anyone is wondering I chose the TRX BL motor, it's due to the track being very short (70' straights), so the avaible torque and no need for high RPMs I felt it was a good choice.
Also, when the need for speed hits I can drop in a 3s and probably not regear for some blazing speed runs.
AMorgan
07.25.2010, 02:48 PM
Lol, busted. Looks like a great build though. I've always wanted to build one of those.
ANGRY-ALIEN
07.25.2010, 03:14 PM
Gosh!! needless to say that thing will fly!... Great job on the build man... will you be making any vids during testing... I would love to see how well it moves.
Alien
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.25.2010, 08:22 PM
Alien
Yes, very light indeed !
Probably no video during testing, I will try to get some Monday night at the races and if worthy I'll post them up
DCastaneda
Speed Addict
DCastaneda's Avatar
07.26.2010, 01:05 AM
He's got the hook up, how far are ya from UF Bondo?
Durango DESC410r MMM CC/Neu 1410
B4.1 Worlds MMP RevTech 17.5
SC10 MMP RevTech 17.5
XRAY T2R MMP Duo3 10.5
SC8E MMM CC/Neu 1520 6s
Inferno GT HV- W.I.P. 12s CC HV110
  Send a message via AIM to DCastaneda
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.26.2010, 08:04 AM
Don't know, Wheres University of Fruitcakes ?
DCastaneda
Speed Addict
DCastaneda's Avatar
07.26.2010, 10:06 AM
Lmao, University of Florida is in Gainesville, just above Ocala
