Charging at more than 1c with Duratrax Ice?
Emaxx_Quebec
Emaxx_Quebec's Avatar
Charging at more than 1c with Duratrax Ice? - 11.02.2010, 08:27 PM
Is it safe to bypass the 1c limitation by lying on mah capacity?
Ex: I have 3s 5000 so I can't charge at more than 5 amp.
If I set it up as 7500 mah, I can charge at 7.5 amp.
Will it peak correctly or not ( And I use a LBA10)
Is the mah setting is there as a title or it does somethig at the charge (Peak).
Thanks
Fred
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
11.02.2010, 09:17 PM
The ICE is technically a 1C charger, but like you said, if you set the capacity higher it raises the maximium rate of charge. Assuming the pack can support a higher rate of charge this is fine to do. The pack will not become overcharged, since a LiPo charger will always stop at 4.2 V/cell- just make sure the # of cells is set right (obviously?).
Emaxx_Quebec
11.03.2010, 08:36 AM
That's what I tought but just want to be sure!
Thanks
