Will it hurt an ESC if it is switched off at WOT?
Lizard
Lizard's Avatar
Will it hurt an ESC if it is switched off at WOT? - 12.03.2013, 11:48 AM
I'm thinking about using a 433Mhz remote relay as an extra precaution to avoid runaways. I would connect it instead of the on/off switch to be able to shut down the ESC remotely and independently from the receiver in case something goes wrong.
Will that cause damage or otherwise hurt the ESC (Mamba Monster)?
Has anybody tried that or had a broken on/off switch that would switch off the ESC while going WOT?
