an unlucky day
Shonen
Shonen's Avatar
an unlucky day - 01.16.2011, 05:39 AM
I had a very unlucky January 7th...I fried two of my Mamba Max Pros that were previously working perfectly. Here's some photos for those who are interested:
completely normal looking...except that this ESC has suffered from reverse polarity. huge cloud of smoke and melted bullets. the ESC still 'works', but the startup beeping causes 60A+ surges with my 1717. Normally it's under 2A, so I think most of the mosfets are blown.
lipo connectors melted the hard case, and the wire desoldered itself. The 4mm bullets themselves are scorched and deformed too. The heat in the wire was so intense that the heatshrink split off the Deans connector, as there was a nick in it from rubbing against something. This was all caused by five seconds of reverse polarity. It's not the best idea to do testing on a build at 2am
the second MMP was killed later in the same day, around 10pm or so. This one was in an E-Revo, and was previously running perfectly fine...geared 18/54 with the two-speed kit, using a Novak HV 6.5 motor on 4s lipo. (I guess I should've known that something bad would happen, the MMP is not rated for 400A like the Novak HV Pro, har har.) We added an external BEC to see if it would stop the Spektrum receiver from rebooting. It appeared to work, that is, until something shorted and another huge cloud of smoke came out.
seems like a copper bus exploded, and solder sprayed everywhere.
Fortunately, the + lead desoldered itself and disconnected before it completely caught fire...
I also noticed a change of the heatsinks. The one on the left was purchased on March 08 2010 and the one on the right was purchased on October 14 2009. The older heatsink had a glossy finish, while the newer heatsink is more matte, like the other Castle ESC's I have (Micro Pro, Monster).
internal comparison. left side is the newer one.
I sent the two MMP's out today for out-of-warranty repair, along with a Phoenix ICE 100 I have that was affected by a service advisory. The customer service rep (Jenny Wendel) was very helpful in answering questions over the past couple of days.
Quite a depressing day...but fortunately the MMP ESC's were the only things damaged. I'm looking forward to getting them back, but until then one of my E-Revos and a 3.3 conversion are out of commission...
