1s lipo chargeing question
candy76man
1s lipo chargeing question - 03.14.2011, 08:30 PM
I have a small heli that uses 600mah 1s lipos. If I set my lipo charger for .6 amps and 1s will it know when to stop charging the way it does when I charge packs with multiple cells and a balance plug? Could I safely charge it at a higher amp setting, 1 amp maybe, or should I keep it at .6 amps?
Or am I better off sticking to the wall wart charger thats made for them?, it usually charges them up in about 45 minutes.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
03.14.2011, 09:47 PM
Honestly, I'd stick with the wall charger that came with it. If you really want to use the other charger then stick to a 1C charge rate (0.6 amps). The charger will work fine- no balancing is needed when charging 1s and the CC/CV cycle is the same.
