My truck / one moretry
neweuser
neweuser's Avatar
My truck / one moretry - 04.23.2006, 07:18 PM
Here ya go guys, let's hope it works!
http://livedigital.com/accounts/welcome/
neweuser
neweuser's Avatar
04.23.2006, 07:20 PM
I think it did!!!!!!!!!!!!!!!!!!!!!!!!!! A lot more work needs to be done on it...but it still is fun. Haven't totally got it complete and runnin yet. Still need screws that will fit the strobe. 4-40's DO NOT work, but i think i know which to use.....3mm's should. Also still need a ubec...
coolhandcountry
coolhandcountry's Avatar
04.23.2006, 07:25 PM
I can't see the pic cause it say I am not a member.
Sylvester
Sylvester's Avatar
04.23.2006, 08:43 PM
Same here, it doesnt work.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
crazyjr
crazyjr's Avatar
04.23.2006, 10:10 PM
sign up page here aswell
neweuser
neweuser's Avatar
04.23.2006, 10:13 PM
darn, need to make them public...i'll get it in awhile...sorry.
neweuser
neweuser's Avatar
04.23.2006, 10:29 PM
try this... emaxx.livedigital.com
neweuser
neweuser's Avatar
04.23.2006, 10:32 PM
OK, try this... http://emaxx.livedigital.com/
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
04.24.2006, 08:13 AM
looks good, but here's a suggestion......you should switch the bl controller with the receiver.....this will cut down on wire length ect.....but overal it looks great....good.. job
  Send a message via MSN to sjcrss
Sylvester
Sylvester's Avatar
04.24.2006, 07:50 AM
It works now! Nice truck! Very neat wiring!
Losi 8ight e
neweuser
neweuser's Avatar
04.24.2006, 09:29 AM
Thanks guys. How do like the mod mount job that i used for the controller!!! Does my parrallel look right? it seems two neg wires will be going to one battery? is that correct? I still need a ubec though!
neweuser
neweuser's Avatar
04.24.2006, 09:46 AM
Also, the other question i have is, the wires that go into hte receiver. I'm not sure which ones the neg pos and so forth. i have orange, brown, and red think....so which way does the plug go into the reciever? Can you see it in the pics? Also, i pulled out the black jumper, do i need to do anything else to the controller?
sjcrss
sjcrss's Avatar
04.24.2006, 09:55 AM
your wires on the esc for the batteries looks correct....just make sure you have them like the following.....from the esc....black wire (-),(+)to(-),(+) red wire to esc......as for your other question....the brown wire should be in the rx the same way your servo wires are...ie...black wire on servo lead.....hope this helps....
neweuser
neweuser's Avatar
04.24.2006, 09:57 AM
i'll check it out. i won't need to pull any wires from the connector as i pulled the jumper out right?
sjcrss
sjcrss's Avatar
04.24.2006, 10:12 AM
correct.....
