just finished, pretty satisfied. though i have some minor things left like solder connectors, mount receiver, paint, get an 8s ore two 4s battery, also thinking about cutting a hole in gear cover for the pinion as its slightly rubbing and maybe glue a plastic cup over so its sealed, may also shorten the gear cover screws and just bolt it right to plate and instead use tape to mount the cover.
still not sure how to remove those small stripped screws holding the tranny plate and esc, i may just cut the head off and remove the plate then remove the rest off the screw with a plier.
also i had a hard time align the motor plate with the small chassie brace, as you can see in the picture its slightly warped.. everything aligned except that thing.
still wondering about the 5sc\t gearing, it have bigger wheels(more speed with same gearing and rotation mass), body and so on.. and if i want to try it out with 6s will it still have enough power ore will i ruined the esc\motor? according to my bathroom weight its 14kg with 6s battery
