This is a highly custom center diff Savage that I designed and CNC machined by a professional machinist.
The specifications:
- 5mm 7075-t6 TVPs, bombproof I would say. 1 inch extended as compared to normal FLUX
- 8mm 6082 aluminum diff holder and motor mount (fits majority of the 1/8 buggy/truggy center diff).
- battery holder need to be fabricated. The one in the picture is a prototype that I fabricated using Kydex (very tough thermoplastic). They are lots of mounting holes designed on the TVPs, so you can use your creativity to fabricate your own battery holder.
What will be included (as per the last picture):
- TVPs
- diff mount and motor mount
- 100mm and 120mm drive shaft (pin to pin)
- modified innovative-rc nitro engine plate (
http://www.innovative-rc.com/engine-...vps-p-279.html).
The parts are all brand new never run except the engine plate. They were only used to mock up the whole assembly. If you know about one-off CNC machining cost, then you will appreciate the price that I am asking for. PM for prices.
