Turnigy Trackstar 150A GenII ESC -
10.21.2014, 02:22 PM
Wanted to share some pics and infos about the Turnigy Trackstar 150A Gen2 ESC I recently bought.
The plan is to run the ESC in my XO-1 powering the Turnigy XK5682-900KV motor.
Generally, the ESC seems to be okay from a build quality perspective as far as I can see.
What's not so nice is, that the two PCBs are not soldered to each other, they are using pin-connectors. Not sure if that matters only in theory, but I guess this could be a source for problems, especially with offroad usage.
From a cooling perspective it's not too good IMHO. The FETs on the upper side have heatsinks that are soldered to the PCB, but there is air between the FET case and the heatsinks, so the heat has to travel through the PCB and then to the heatsinks. The lower FETs don't have any heatsinks at all, they rely on the PCB cooling path. On top of the heatsinks there is a thermally conductive pad which is needed to compensate for the difference in height of the heatsinks. On top of that, there is the orange heatsink.
The heatsink is screwed on from the underside which causes the PCB to warp a little from the pressure.
But that is actually a good thing if you want to improve cooling yourself, since everything can be removed. On Mamba Monsters for example, the Heatsink is glued to the FETs, impossible to remove.
Here are some pics:
10.21.2014, 08:51 PM
From the looks of it, the bottom un-heatsunk PCB is the brains, so should generate little heat. I've seen lots of boards connected with pins like that, and as long as the case holds them together, there should be little concern even for off-road use.
And about the dual heatsink thing: FET packages are relatively poor at transferring heat, which is why they soldered the heatspreader to the PCB - which will pull heat from the FET faster than any HS on a plastic FET case. Then, they use the main large heatsink to dissipate the heat pulled from the heatspreaders. And even though the FETs on the underside of the PCB are not directly heatsinked, the large traces should be more than sufficient to transfer the heat upwards. IMO, not a bad design to be honest.
A better option to me would be to use FETs that have a low rdson and a high slew rate - those two factors alone can result in less heat to be generated in the first place. Those FETs have an rdson of ~3mohm and a rise/fall time of ~50ns. Not sure how those figures compare with FETs of other current generation ESCs, but that's something to look at.
10.23.2014, 04:07 AM
The Tekin RX8 has the 2 boards also connected by a row of pins.
I never had a problem with that and I assume that Tekin has done it's homework?
10.24.2014, 07:14 AM
hi,
where did you get the cap bank?
I think that its not a problem that the two layers are sticked together with pins, have seen that a couple of times.
Manufacturer should be sky rc, isn't it?
here some pics of mine, which has a different layout, dunno if the fets are the same
http://www.rc-monster.com/forum/show...465#post428465
10.24.2014, 11:26 AM
Well, if that cooling design isn't bad at all, then I'm going to try it like it is :)
Not sure if it's really necessary to use lowest-resistance FETs, atleast Uber on rcgroups says it's not needed when ESCs are properly designed. It's just a few watts, if you have the cooling to remove the heat that doesn't matter I guess (?)
Regarding the pin connection: Maybe it's just a theoretical problem, but I think it is a possible cause of failure when run offroad with lots of vibration, shocks and dirt. Those connectors are designed to be used in computers and other stuff that doesn't get abused in the dirt like RC cars do.
The cap bank is selfmade from a piece of "Lochstreifenplatine" (not sure what that is in english, that kind of circuit board you can buy for making your own circuits).
08.05.2015, 02:59 PM
For the FETs, there are many other considerations besides the on-resistance, but in general, lower is better, and more expensive.
One of the big reasons not to use higher resistance FETs is the energy that the die can absorb. The lower the resistance of the FET, the larger the die (the piece of silicon that is actually the semiconductor) and therefore the cooler the die runs.
"just a few watts" is enough energy to destroy a FET, and can make a HUGE difference in survivability of a controller.
Heat sinks can only do so much, because the package (the plastic and metal surrounding the die) has significant thermal resistance. So during high energy events (fast acceleration, hard braking) the die temperature rises much faster than the heat sink temperature.
Th larger the die, the more survivable the MOSFET.
Today, there's no reason to use a 3 milliohm MOSFET, other than maximizing profit. It's easy and fairly inexpensive to use better FETs with much larger die.
Thanks!
Patrick
Patrick del Castillo
President, Principle Engineer
05.18.2015, 04:45 AM
Finally put the Trackstar ESC and the Turnigy XK6582 900KV motor in the XO-1. Luckily, the 56mm motor fits without any special motor mount, just had to drill two additional holes into the stock mount. The ESC mounting plate also fits the holes already in the chassis
Added three 1000uF 35V Low-ESR caps and removed the cooling fan (wanted to add bigger fans later). Used the 46t XO-1 spur gear and a 36t Revo spur gear with an adapter as a pinion gear. With the 4.29 inch XO-1 tires that translates to 112kph/h unloaded with 3.7V per cell.
Well, it didn't turn out too good. When I switched on the Traxxas TQi, it wanted me to do an update. Did that. Then, suddenly during the updating process, the TQi decided it was a good idea to send a full throttle signal to the ESC. Quite scary. Luckily, I always put something under the car so that the tires were in the air. Disconnected the battery cable then and re-did the update without ESC connected using an external battery pack to power the receiver.
Powered it up again, and tried to run it. It coggs like crazy, it's almost impossible to get it moving. Motor, ESC and cables stay cool though. Not sure why that is, hopefully it's not because I damaged the ESC by pulling the battery lead when it was running unloaded full throttle (?) Or maybe it's just not "compatible" with that Turnigy motor? I guess I have to try it with another motor ...
05.18.2015, 01:35 PM
Ah crap man, sorry to see you're having bad luck with this (too)..., looking forward to seeing you tackle this. Curious how things will go with a different ESC. You have a spare Mamba laying around for a quick test?
05.19.2015, 10:33 AM
Unfortunately, no. Two Mambas in the twin and the third is in the Slash again (I put in the 1717 and Mamba so I can drive while the Alienpower is being repaired).
Hopefully we get the VESCs soon, then I have a spare Mamba again :)
05.22.2015, 03:10 PM
What vehicle are those in???
05.23.2015, 03:03 PM
06.16.2015, 10:06 AM
Hey man, curious how your motor is going to hold up. Mine smells like a BBQ gone bad :D... You probably know a bit more on what 56/58 mm motors have been working well in XO-1s, so let's say, "hypothetically" :D, you would be looking for a replacement for the 5682, any idea what you would be considering? - Leo 5682/5692 ~1300 kv seems very popular, but I'm worried quality will be around that of the Turnigy (afaik the specs of the 5682 900 kv versions were identical except for the max RPM, so could even be same stator, different rotor???). Maybe the higher kv ones will hold up better under higher Current loads though.
- TP5650/60 is also tempting, especially considering the additional poles, but a bit more expensive. Bruno has a custom ~1400kv version I'm tempted at, but you never know what you get with those custom winds, and your experiences with APS were also not the smoothest...
- Toro Beast X24 are quite cheap and huge (102 mm long, 1100 g); they have a 190A 900 kv version, which means I don't have to rethink gearing (might also mean I burn it up again...). And it's cheap, and big. But I can't find much about people using them... Did I mention already it's big, and cheap? :D
Anyway, sorry for polluting your thread man, just like to bounce some ideas with you.
Cheers!
06.16.2015, 12:59 PM
Hmm, crap that yor motor didn't last long.
I think I know no more than you. Leos are not very good is my feeling, have heard reports on my local track that the Ripper 2000kv in various Thundertiger cars gets hot and doesn't hold up. And from what I see from online pics they don't seem to be very high build quality. Your experiences were also not good (regarding efficiency).
Have also seen some people with the 56x82 1360kv Leopard in the XO-1,
but somehow nobody posted any real info on them.
IIRC, Othello ran the Toro Beast sometime ago in a 5th scale, maybe ask him or search on the offroad-cult forum.
Personally, I'd take a TP58xx around 90-100mm long (I'm too lazy to look up their weird model numbers now ;)), with a KV that gives around 30k RPM, but I have no idea if that would be a good setup. Not sure if that 30k RPM rule of thumb also applies to larger 6-Pole motors...
Oh, regarding Alienpower: I got my stuff back finally. The broken ESC and the motor is exactly like I sent it to Bruno, no work done there. But Bruno said, there was one sensor defect in the motor and also something with the ESC and that he would repair it. Later then he told me, there was too much modifying done on the motor and ESC to be repairable (nope...) and he would send a new ESC.
Well, the ESC was the package, but only a non-sensored one. And the program card is still missing, got another USB adapter instead. Definetely not recommended.
06.16.2015, 02:17 PM
Yeah, I hope you can have some more fun with it. It seems the cheaper motors (Turnigy, Leo, Toro) with low kv have quite low Current ratings, mainly depending on higher Voltage to produce enough Power. The TP motors are specced a bit higher Current-wise for same kv/size combos. I thought I could keep the Turnigy happy with some cooling, but the 106 A rating seems quite realistic. If you want to try a higher Voltage on yours to see if you can keep the Current low enough, you can have my rotor as a spare whenever the post stops striking.
I asked Vedder already if he can say anything about generalizing that 60k electrical RPM as optimum trade-off point between copper losses (I^2*R: high at high load - low RPM) and non-copper losses (Eddy Currents, hysteresis and whatnot: high at low load - high RPM), as he explicitly mentions on his site that it comes from his experience with 14-pole, 50-60 mm dia outrunners. Curious if he can elaborate a bit more on the principles, but the thing for our RCs is that we typically go through the whole RPM range constantly anyway, so there's a constant change in the dominance of the copper vs. non-copper losses, depending on in what phase of the run you are... although that's my noob thoughts on it :).
I'll have to give the motors some thought still, but I am realizing Current rating is not as unimportant and can't be boosted as easily with aircooling as I thought.
Thanks for the info!
06.17.2015, 09:53 AM
At some point the wire thickness and resistance plays a part. No matter how hard you cool it. :)
That optimum point; I think it might be a bit more complicated and setup-dependent. Artur could elaborate on that much better than I ever can.
It also depends on timing. These new controllers with a timing-boost should be able help to get a higher top-end as well (I mean the ones that up their timing towards the end of the end-rpm) Never found a movie on youtube to back this theory though
