380c 6t...can it handle 8 cells?
Thunderbruiser
Thunderbruiser's Avatar
380c 6t...can it handle 8 cells? - 06.26.2006, 07:44 PM
I have an xtm xcellerator and have spare quark 80b+380c 6t...i was wondering could it handle between 7-8cells?
Caster Racing Team 09'
Sik Wit It Racing Crew Fo life
garage:
E-CRT.5 brushed for now 13x2 orion(tekin g20)2s 5200mah lipo
  Send a message via Yahoo to Thunderbruiser Send a message via AIM to Thunderbruiser
cemetery gates
06.26.2006, 07:52 PM
i believe that that motor is pretty much limited to 6 cells or a 2 cell lipo. BTW that motor is too hot for a stadium truck IMO. what about a 380c 6L that should handle 8 cells and do very nicely. :018:
Thunderbruiser
06.26.2006, 08:00 PM
well i'll just run 6 cells for now but i also have a 2s batt pack that i'll run in the future...i want this truck to be really fast btw...so i like that it's overkill
garage:
cemetery gates
06.26.2006, 08:04 PM
from what I've been reading it is. You could try it but it will run hot. It might work if you gear down alot.
Thunderbruiser
06.26.2006, 08:33 PM
well yeah if it runs too hot then i'll gear down and or get a 6l but for now i'll run it
garage:
Thunderbruiser
06.26.2006, 09:57 PM
runnin 16/90 what would be good for an st with standard sized frnt/rear tires? running 0n 3900's right now...maybe 2s in the future
garage:
cemetery gates
06.26.2006, 10:39 PM
gearing sounds good to me, but if you run 8 cells maybe drop to a 15 or 14 tooth pinion.
ygguB naM
06.26.2006, 10:34 PM
Eight cells will be pushing the limits, the motor'll be at 65,000 rpm unloaded so make sure u watch the temps and u should be ok.
Thunderbruiser
06.26.2006, 11:23 PM
well the darn esc won't program correctly no matter what i do...so i'll wait until am DOne being annoyed!
garage:
