12.16.2006, 02:59 PM
That's odd, mine came set to 50/50. Like I said, make sure the throttle EPA in both forward and reverse is set to 100%-125% and the trim set to 0. This should set it up for 50/50. Once this is done, you could try reversing the throttle channel, but I don't remember having to do this.
Do you have the Spektrum system or a module setup? If using a Futaba-based radio, you will have to reverse the throttle channel...
A dumb question, but do you have the throttle connector plugged into the receiver correctly? Having it in the wrong way won't hurt anything, but it won't work.
What about power? Are you using the MM BEC, external UBEC, or receiver pack?
