HSR Motorsports Slipper Photos! -
01.23.2007, 10:57 PM
Initial photos are of the prototype. Minor changes have been made for the production version.
01.23.2007, 11:00 PM
finally nice. it is a good idea i have not purches my strobe stetup yet this could be a better option but it will be a month or so before i buy this setup(slipper setup) for my maxx and this setup of yours definatly looks promising will it work with h1 speed conversion thanks for pics keep up the good work.
01.23.2007, 11:03 PM
Looks cool; you should sell this to traxxas if they do a 3.3 spec e-maxx:005:
What spurs do they use? MGT, t-maxx 3.3, revo?
Thanks!
Bye:018:
01.23.2007, 11:01 PM
There will be a single speed version for the G-Maxx Single Speed Conversion.
01.23.2007, 11:02 PM
I hope to offer these thru Mike here at RC-M. I need to discuss this with him further.
how does the thing actually work i mean attach i can not really see the wording on the pics very well if you dont mind could you ellaborate on the benifits of this and how it works and is installed thanks
01.24.2007, 10:28 AM
Revo spurs work if you can make use of the 36/38/40T options. T-Maxx3.3 spurs fit but are NOT MOD1 pitch. MGT's gears are mod1 but do not fit the REVO3.3 spec slipper.
Spurs are custom for the slipper and use MOD1 pitch.
01.25.2007, 01:23 AM
I disagree :004:. If you drill out three of the slipper peg holes in the MGT spur (in a triangular pattern) to 5mm, and drill the center hole to 10mm, you can mount MGT spurs to the Revo slipper clutch if you use a 5x10mm bearing in the gear and washers under the screws holding the gear on. It's a tight fit onto the Revo slipper clutch, but it fits. This is a great way to get a 52t mod1 spur onto a Revo slipper clutch :027:. And best of all, the gear is only $3.50.
01.24.2007, 05:03 PM
Looks good! Is that the stock pins holding in the gears? They are horrible.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
01.24.2007, 05:07 PM
No. The picture (I guess is was a bit blurry, or the compression messed it up) shows a hardened steel pin pressed into the first gear and a std. roll pin (weak!) in the second.
My slippers will have pressed steel pins in both gears.
The picture is of the prototype. Production pieces are not yet available.
Anyone know the thickness of the G-maxx motor mounts?
01.24.2007, 11:18 PM
no but it might say on the website if i had to guess i woulkd say two to three milimmeters.
01.24.2007, 11:30 PM
2-3mm? Wouldn't that be very flexible? I think it would at least be 4-6mm...
Bye:018:
01.25.2007, 12:13 AM
Bye:018:
The base or ( vertical part) of the MM is between 4-6, & the tab were the motor mounts too is 3mm.
Procharged you did a good job on your slipper setup ,i like it.
01.25.2007, 12:58 AM
Thanks hippie!
Production pieces are not far off. I've had trouble with the Delrin spurs mostly.
I was asking about the GMaxx motor mount so that there was adequate clearance between the slipper and the motor mount. I have a 4mm motor plate with 3mm clearance on the slipper. so a 6mm mounty should have just enough clearance.
Anyone with a G-Maxx motor mount................
Can you measure it for me please????
01.25.2007, 01:11 AM
Is that a new shaft? or, Did you use the stock shaft?
too bad i'm going slipperential, I'd have picked the first one up
