Schulze 18.97 No Reverse
Compliantguy
Question Schulze 18.97 No Reverse - 06.05.2005, 02:13 PM
I'm using a Schulze 18.97 controller with a Plettenberg MAXXimum and I can't get my E-Maxx to go into reverse. I have the micro switch set to the proper position, according to the instructions. Any ideas??
Thanks.
rchippie
rchippie's Avatar
06.05.2005, 02:33 PM
I'm looking at the manual know it says the # 3 switch should in the # 1 postion. You might want to try doing the programing with power off. You may also want to check your radio for proper settings.
REAL MEN RUN BRUSHLESS
Serum
Serum's Avatar
06.05.2005, 05:11 PM
YEAH!
keep the gas on at least 75% of backwards/brake for at least 2-3 seconds. It will reverse, somehow.. Eventually.. when it feels like reversing.. if you ask it polite..
Don't you love your schulze?!
Dafni
Dafni's Avatar
06.06.2005, 02:47 AM
Oh gosh, is this something that every 18.97 has?
Sounds aweful.
Serum
Serum's Avatar
06.06.2005, 03:14 AM
I somewhat dramatized it, it will reverse, but you need to wait 2-3 seconds before it does..
Compliantguy
06.06.2005, 05:34 AM
I'll give it a try this afternoon, with a little more patience. Thanks for the info!
Serum
Serum's Avatar
06.06.2005, 06:41 AM
Okay, please let us know if it works.
Compliantguy
Thumbs up 06.06.2005, 09:28 PM
Well, I figured it out! I had to adjust the Brake End-Point Adjustment (EPA) to 75% and now it works. Duh! I should've known that it was something simple like that!:D Everything is good to go now.
Serum
Serum's Avatar
06.07.2005, 01:54 AM
allrighty then...
Glad you got it figured out.
