How could I go about getting them more precise aurtur? I am planning on a couple of 14L for this and they rated like 44 amps. I think I will give it a go.
When you connect them via spur and pinions together, they should spin freely without any hesitation. If not then you need to move 1-2 tooth left-right until that happen and for identical (14L and 14L) motor you should track each-other very good; precisely I will say. You should be fine with 14L, startup problems with higher inductance motor should be less visible.
Artur
