Lipoly check
Rcbros
Rcbros's Avatar
Lipoly check - 08.10.2005, 01:30 AM
I got the Feigao 9L and Warrior 9920
Will this setup work
2 5S packs
I would get 18.5 Volts. Thats 18.5V at 68 amp. That is 1258
Is that o.k.?
What run times would I be looking at?
  Send a message via Yahoo to Rcbros Send a message via AIM to Rcbros
MetalMan
MetalMan's Avatar
08.10.2005, 07:37 PM
5s is an awful lot to run one the 9L. I would say too much. 4s would work better, IMO. Also, there's no way you can get 18.5v at 68amps from a pack, unless it was rated to handle 90amps!
Runtime depends on the Lipo pack you get. Which one are you looking at?
Rcbros
Rcbros's Avatar
08.10.2005, 10:23 PM
Metal Man,
I told patrick over at maxamps the specs on the 9L and warrior 9920 and that is the exact setup and words he gave me.
Re~Mix
ĄGo Baby Go!
Re~Mix's Avatar
08.10.2005, 11:27 PM
That's way to many volts through the 9L. Go to the 10L on that.
RC18T FT - Quark Castle Creations Airtronics IB
  Send a message via AIM to Re~Mix
Rcbros
Rcbros's Avatar
08.10.2005, 11:31 PM
so 4S for the lipoly then?
If I run that setup what run times should I expect.
MetalMan
MetalMan's Avatar
08.11.2005, 01:00 AM
For what capacity?
