Revo Tranny Questions
Revo Tranny Questions - 03.05.2008, 11:15 AM
I was wondering if anyone here runs a revo tranny, locked in second, with the center diff? I would like to use the motor brakes on this revo project, but would also like to try out the center diff.
I understand that braking will not be as good, due to lack of adjustable bias. Not really a problem as I will most likely just bash with the truck.
Also wondering what weight of fluid would be required for the center diff? From what I have hears the diff requires heavier oil than usual due to the smaller spider gears inside of the diff. That is what I heard anyway.
Proposed setup is the revo tranny, locked in second, hybrid diffs with buggy ratio gears, a MM, 4s lipo, and most likely a 7xl. Motor and esc may be different, not sure about them yet.
03.05.2008, 11:30 AM
is it going to be a custom conversion or are you going to use a kit? if your going to use a kit, try out the blue groove concepts one, ive been curious about it- although the motor mount doesnt look that good, id replace it with the rc-m one.
03.05.2008, 11:38 AM
Well, I have a tekno battery tray and straps, and a rcm motor mount. Not really much else needed, save for an esc mount and a rec mount. I will most likely make a plate over each shock mount to hold the rec and esc.
I have an off the wall revo conversion kit, not sure which one it is. I may use some parts out of it. It has an adapter to munt the old style maxx spurs to the revo slipper, and some sort of internal tranny coupler. I will have to disassemble the tranny to see what it does to lock it.
BrianG had it listed in his thread about locking the tranny in second gear. I ended up with the complete conversion due to late night bidding on ebay!
03.05.2008, 11:55 AM
sounds good. hmmm... the only revo conversions i know of are: tekno, gorillamaxx, bgc, and rcm. i wonder what you have. is it custom made?
kingiggy262
BL-Revo
03.05.2008, 02:17 PM
I am currently in the process of creating a brushless Revo and chose to use a center diff with Ofna diff lock lube. I hear it works good for bashing and doesn't unload too often. I'll be running MM, 8XL, and stock diff's with a 4s Lipo. Tranny is also locked in second.
Hopefully I will be able to test it out soon!
03.05.2008, 07:37 PM
Ok, found the conversion info.
http://www.eaglesviewaerial.com/revoelectrickit.html
I like the motor mount, and may give it a try, along with the speed control mount. Most likely will use the tekno battery tray, and will run dual steering servos, as that is what I have.
Motor will be a hacker c50 13l and a quark 125b on 5s lipo. Sound do well as it is almost the same as my emaxx setup, cave for the maxx has a 15l hacker.
Gearing at 17/40 with the tranny locked in 2nd, and buggy ratio diffs gives me right at 40mph.
I will try out the center diff, and see how it does with the 50k traxxas diff lube.
I will post some pics of the tranny mods, as they are different from the others that I have seen.
