Little cooling help for MM Muggy?
ilpufxit
ilpufxit's Avatar
Little cooling help for MM Muggy? - 03.24.2008, 08:11 PM
I've been running my BL Muggy for a while now. It works great, handling is awesome, flies really nice, rarely breaks. It's as fast as I would want it to be (about 40 MPH). My setup is; Feigao 8xl, 14t pinion, Spider Diff, Modded MambaMax, MaxAmps 6000 4s.
My problem is, I always thermal the ESC after about 10 minutes. The motor is pretty warm but not hot. When I stop and recharge, I'm usually putting 3500mah back into the pack.
What's the best way to get the whole pack through it at once? I'm not a big fan of fans but without losing speed, what are the options? My MM won't run on 5s or I would go that way. Any ideas?
chilledoutuk
03.24.2008, 08:19 PM
well i suggest you become a fan of fans otherwise your asking an impossible to answer question without modifying and invalidating your castle warranty.
you could remove the castle heatsink and put a larger one on or alternatively buy a more efficient motor like a neu motor or similar.
you could always pickup a mtroniks controller and using thermal epoxy attach it to your chassis for sinking.
other than that until the mmm your Donald ducked if you don't want to use fans.
03.24.2008, 08:20 PM
the spider diff can have multiple spur sizes, we need to know spur gear count and is it a losi muggy? are the diffs 13/43? then we can help more, offhand i'd say drop down a couple teeth on the pinion
spur
ilpufxit
ilpufxit's Avatar
spur - 03.24.2008, 09:03 PM
I just counted. It's a 46t spur. It's a losi Muggy with Muggy diff gearing. I guess what I'm really wondering is how much of a gearing change would it take to make the difference. If I could give up a little top end speed, that would be a fair trade. The torque is already more than I need but there is a little cogging from a dead start.
03.24.2008, 09:07 PM
1 tooth drop on the pinion would not be very noticable and may help heat issues. 2 teeth would most likely do it, but that would knock off a few mph.
Just get a novak 2700 cap and solder it to the main leads close to the board. That may do the trick, and costs about 10 bucks!
Also, reattaching the heatsink properly will help too, the stock thermal glue is not applied very well.
03.24.2008, 09:32 PM
using the speed calculator going to a 12 tooth pinion drops off 5mph, but how often are you at top speed? that should help your cogging too.
VintageMA
VintageMA's Avatar
03.24.2008, 09:33 PM
Another question - what are your MM settings for the following:
Punch Control
Motor Timing
Startup Power?
I've had several conversation with the Castle guys on the phone and the "Normal" setting for Timing is like a 10% advance on timing. They recommend setting the following:
Timing - Lowest
Start Power - Low
Punch Control - up to the batteries you are using. If you have punch control set at 0, try kickng it up to 30% and adjust it from there.
“Everyone has a right to be stupid; some people just abuse the privilege.”
bdebde
That's All Folks!
bdebde's Avatar
03.24.2008, 08:50 PM
he likes the speed as it is though. diffs are 11/45.
You can try using caps on the incoming battery leads (as close as possible to MM), some people have seen reduced temps this way. I would definitely run a fan on a rig that heavy myself. I run fan on my 1/8th buggy with MM, even though it never thermals without a fan.
VintageMA
VintageMA's Avatar
03.24.2008, 08:56 PM
Two choices - either use a smaller pinion - or get a fan.
My suggestion -
Novak fan: http://www3.towerhobbies.com/cgi-bin...?&I=LXKKN0&P=7
Screw it directly into the ESC and if you have an extra channel on your receiver, plug it directly into the + and ground and you'll be set to go.
Also - depending on the location of you ESC mount cut some holes in your body to encourage some air-flow over the ESC when running.
bdebde
That's All Folks!
bdebde's Avatar
03.24.2008, 09:06 PM
what size pinion you running now? (*edit*,saw it) I would try dropping one or two teeth. If the torque is already too much, try using some punch control, it may keep things a bit cooler as well.
Takedown
WARNING: May become violent.
Takedown's Avatar
03.24.2008, 10:22 PM
I would run a ducted fan over it like my friend does. It cost the same as a regular fan yet puts out a alot more wind and is very efficient. Here- http://www3.towerhobbies.com/cgi-bin...?&I=LXHHP1&P=7
03.24.2008, 10:31 PM
Hmm, just use a larger ducted fan unit, place the esc in front of it, and use it for thrust. I would think that a 1515 powered ducted fan unit would be reasonably powerful, and the intake would flow plenty of air over the esc...
Takedown
Takedown's Avatar
03.24.2008, 10:55 PM
Hmmm... I would just go for the small ducted fan because its cheap and you dont have to mod anything. "Much Easier"
lydiasdad
03.25.2008, 12:13 AM
I never understood why so people are against using fans. Even if you are geared correctly, the cooler the esc the better.
entjoles
03.25.2008, 12:25 AM
what mods are done on your esc.
the cap should help some , and also put some holes in the case
