Savage + 6s + KB45 8XL = Total un-useable insanity....
BOOGIE444
Savage + 6s + KB45 8XL = Total un-useable insanity.... - 05.01.2008, 09:11 AM
Here is my setup...
Extended 14lbs+ savage locked in 2nd gear.
Turnigy HV esc
Zippy-H 6s 4000mah 20-30c
20 tooth pinion
48T steel spur gear
KB45 8XL 1700kv
I ran this setup last nite for around 5 min and the batteries didnt get above 80F and the motor was barely at 100F but I couldnt really use anything more than 1/2 throttle. The kb45 motor is just waaaaay too much power, I can wheelie on 1/4 to 1/2 throttle all the way down the street.
Punching it to full throttle results in a back flip instantly that almost gets it back on to its wheelies without the body hitting the ground. Yeah I have a wheelie bar but it actually misses it because it does back flips on full throttle.
What can I do to tame this thing down? I would have to mill a longer slot in my motor mount to put a bigger pinion on, but it is possible. I have a mamba monster coming inbound maybe that will have software on it to tame this motor setup down? Any other ideas????
To be honest my old setup of 4s + feigao 7XL was plenty fast, I want something around the same speed maybe a little faster but with the effieciency that I am getting with 6s now.
jzemaxx
05.01.2008, 09:54 AM
Some things you can do is dial back the timing to low, and swap to 5S. That will help,or re-gear a little higher to cut some torque out.
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
big greg
05.01.2008, 12:03 PM
man with that thing you will probably gear up and have even more torque!
BOOGIE444
05.01.2008, 01:00 PM
Lunch time run update....
I changed some settings on the turnigy HV esc to super soft start and low timing. Its still rediculous though but sort of driveable if I ease into the throttle I can now use full throttle. Although I think I need new brakes or something because this little sucker is fast and hard to slow down.
It still wheelies like mad but if I practice some throttle control I can catch it before it back flips beyond the wheelie bar. I think if I geared up to a 25 tooth pinion it would make it much more driveable.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
05.01.2008, 01:06 PM
becarefull of upping your gearing and voltage.... that Motor can easily spike over 150A..
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
BOOGIE444
05.01.2008, 02:10 PM
Thats what my new mamba monster is for
jzemaxx
05.01.2008, 01:16 PM
That motor is a big boy.....my buddy is putting one on his MGT on 10S. Should be another 65-70mph truck here shortly.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
BOOGIE444
05.01.2008, 02:09 PM
I bet my savage could do 60mph on just a 6s setup, the thing is crazy fast.
jzemaxx
05.01.2008, 02:12 PM
You'd be suprised how hard it is to get to 60mph. Looks can be very deceiving.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
aqwut
aqwut's Avatar
05.01.2008, 02:51 PM
It's not easy.. since you have the Turnigy ESC, get the KB-17XL-700KV, and up it to 12S.. . that's what I'm running.. it is just so powerful at any speed... stays fairly cool as well...
BOOGIE.. you're pumping out about 1800Watts... Juice it up man... on 12S and a 700Kv motor, you'll have some serious power...
Then you can compete with JzeMaxx over there.. :)
BOOGIE444
05.01.2008, 03:08 PM
50mph is all I really need, to be honest I am thinking about sticking a feigao 11XL in there to tame the beast down a little. I am sticking with 6s as this will be a racing truck not a speed run vehicle.
Takedown
WARNING: May become violent.
Takedown's Avatar
05.01.2008, 05:31 PM
Anything past 50mph with a 1/8 MT is just asking for either broken parts or other issues. But hey your talking to the guys here on RCM were overkill is not an option.
RIP- Tammy (9/14/08)
jzemaxx
05.01.2008, 05:34 PM
No such thing as to much power..... Lutach, BrianG and Aqwut probably agree with me.....lol
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
lutach
lutach's Avatar
05.02.2008, 12:01 PM
The more the better. I've seen 4760 watts out of my 40.160, 1521/1Y and10S lipos.
Takedown
Takedown's Avatar
05.01.2008, 05:38 PM
I agree with you also JZ but their is limitations but they are very stretched so you will rarely ever run into them if setup properly. The sky's really the limit.
