Neu's come with a flat shaft right??
mk351e
RC-Monster just don't get it
mk351e's Avatar
Neu's come with a flat shaft right?? - 05.03.2008, 10:02 PM
I sure hope so! One thing I DO NOT feel comfortable doing is grinding the shaft flat on my $265 motor? I got a 1515 1Y coming, though I may cancel and get the tekno motor if they can come out soon enough.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
05.03.2008, 10:15 PM
Smooth shaft on the Neu.
If you grind a flat spot, keep debris from getting into the motor. One good way is to use a good strong ziplock bag, etc.... put the motor in it and poke the shaft out though the bag. Then maybe even tape around the shaft to make sure it's sealed good. Grind it with a cutting wheel or sanding drum and take your time.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
05.03.2008, 10:29 PM
I think it depends on stock - I think some of the new ones are coming with it...
azjc
05.03.2008, 10:34 PM
the new ones come with a flat half way down the shaft, as long as you place the pinion on the shaft with the setscrew side closest to the motor you will be fine
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
05.04.2008, 12:25 AM
My NEU motor that I got last week had a flat spot on the shaft (1512) but it didn't go all the way along
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
azjc
05.04.2008, 12:52 AM
lengthwise the flat is probubly 1/3 of the shaft
DRIFT_BUGGY
05.04.2008, 01:18 AM
Yeah pretty much, I only looked at it once and put it back in the box as I can't really use it until the ESC and motor mount arrive
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
glassdoctor
TEAM FUSION
05.04.2008, 09:42 AM
The 1509 I just got didn't have any flat spot... maybe it's from older stock or they are only doing it on the 1512 and 1515?
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
DRIFT_BUGGY
05.04.2008, 06:01 PM
Is there screws on the endbell?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
rabosi
05.04.2008, 12:25 PM
The flat spot on the new neu's didn't match up for me. i had to make my own on the other side. I like using a thin flat file (jewelers) better than the dremel. More control I think.
glassdoctor
TEAM FUSION
05.04.2008, 07:19 PM
yup...
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
