Is It Safe...
camel_rc
Is It Safe... - 09.10.2005, 08:24 PM
To run 9 cells through a MGM Compro 8012 and a Feigao 8s?
captain harlock
RC-Monster Captain
captain harlock's Avatar
09.10.2005, 08:25 PM
What machine are you using?
Nice to meet you!
camel_rc
09.10.2005, 09:07 PM
http://www.rc-monster.com/forum/show...=&threadid=995
coolhandcountry
coolhandcountry's Avatar
09.10.2005, 09:22 PM
that is a light weight truck. If the motor don't over wind would be the question. 9 cell is 10.8 volts x the kv which not sure of. 6000 kv would only turn 66000 rpm. If you try it keep a close eye on temps. I ran a 8l on 18 cells. Not sure if it was safe either but still running the motor today. 3000 kv motor on 21.6 volts 64800 rpm.
Peace!
Country
Help support the
Rc-Monster
Buy here
El Jarretto
09.10.2005, 09:35 PM
That's 47,908.8 RPM's. I don't remember if Feigao's have a 60,000 or 50,000 RPM limit. If it's 60,000 I would try but watch the temps.
camel_rc
09.10.2005, 11:57 PM
I think it's 60,000. I think I will do it anyway even if it's not...just for fun. :)
MetalMan
MetalMan's Avatar
09.11.2005, 01:35 AM
Feigao motors have a limit of 50,000 RPM. You would be safe to run 9 cells. It would be good if you could gear it down a little, but I'll bet you just want the pure speed :).
camel_rc
09.11.2005, 02:07 AM
Well, I figure if it's way undergeared on 6 cells (like it is now) I figure going up 3 teeth should work fine with 9 cells.
Nick
COOKIES!
Nick's Avatar
09.11.2005, 06:44 AM
//Offtopic
Isn't the 8L for around 12 cells? :eek:
How did it perform, did it get hot? Low gearing I imagine too. :D
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
09.11.2005, 07:42 AM
Technically, the Feigaos have a 50000 rpm limit, but this can be pushed without much issue. The real problem will be trying to drive it with all that power! Have fun!
coolhandcountry
09.11.2005, 08:21 AM
IF you have the truck geared right for 6 cells. You need to drop a couple teeth when you go up on cells. YOu may want to try it geared like it is first. Just a suggestion. Even though it may go faster with higher gear.
Peace!
Country
Help support the
Rc-Monster
Buy here
camel_rc
09.11.2005, 11:06 AM
I see...now I need a battery tray for all the cells. What do you guys think? I've got a bunch of 1/8" aluminum, but I don't want it to look hack (I've got a hack saw and a dremel to cut it).
