Will a Mamba Monster work with a CC BEC???
BOOGIE444
Will a Mamba Monster work with a CC BEC??? - 05.14.2008, 03:02 PM
You know if I cut the red wire that goes to the receiver to disable the mamba monster's bec, will it work???
Because I want to use my CC BEC so I can turn the voltage up to my servos and increase reliability because it seems the mamba monster's bec has some issue's in some units out there.
I cant use my CC BEC with my current turnigy HV esc because it makes the esc glitch & cogg like crazy.
05.14.2008, 03:18 PM
Don't "cut" it -just tease it out of the plug and yes it should be fine with a bec.
JerryF504
I don't understand, but I don't think I like it.
JerryF504's Avatar
05.14.2008, 03:20 PM
Yes, it will work fine. I don't know if it will keep a faulty internal bec from quitting because it will still be powering the fan and brain board but it surely won't hurt to take some of the load off of it.
BOOGIE444
05.14.2008, 03:32 PM
Brain board, ah huhuhuh huhuh. He said you need a new brain board Beavis...
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
05.31.2008, 07:06 PM
Would this work? Looking at just making a 1" servo extension lead without the read wire on the extension so I don't have to disconnect the red wire from the esc, so then I could just disconnect the ext. lead to connect it to the pc without having to reconnect the red wire all the time?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
Dewmerz
05.31.2008, 07:09 PM
I usually use short servo extensions with the red wire pulled from the extension for my mamba max. Much easier than pulling the wire out of the connector.
