mmm and power capacitor
e-mike
e-mike's Avatar
mmm and power capacitor - 06.02.2008, 04:07 PM
sorry to create a other tread (if one existing)i want to know if it is good for a esc like the mmm to add a power capacitor!!!!and what is the benefit for the esc,,i just want the best for my mmm
tanks
dirt101
dirt101's Avatar
06.02.2008, 04:08 PM
I think you may want to edit that.(I also edited it in my quote)
e-mike
e-mike's Avatar
06.02.2008, 04:10 PM
tanks sorry for my poor english...
Joe Ford
Castle's Chaos Corner
Joe Ford's Avatar
06.02.2008, 10:04 PM
There is no benefit in adding any capacitors...we put enough on the controller to handle ANYTHING you can throw at it. Do NOT use cheap batteries though. You need high quality cells to run this system...email or call tech support if you are unsure of your batteries' ability to deliver the current. support@castlecreations.com or 913-390-6939 and hit 1 for tech support.
Joe Ford
Product Specialist
Sammus
Sammus's Avatar
06.03.2008, 04:58 AM
Would 7s1p A123 be considered high enough quality? Or would I have to go 2p?
GriffinRU
06.04.2008, 10:53 PM
How you define that?
Why not using cheap batteries? What happen to battery when it is half dead?
What about NiMH?
I thought that bad LiPo are still better then NiCd/NiMh...
Sound like your caps are not up for the task or you just do not want people to add components to your ESC which makes it better.
bdebde
That's All Folks!
bdebde's Avatar
06.02.2008, 10:31 PM
Hey Joe,
Many manufacturers do recommend additional caps for long battery leads. Do we still not add caps if we have to lengthen the leads? I have one rig that the MMM wires are just barely long enough. If I had a longer motor or longer battery, I would need to lengthen wires.
Joe Ford
Joe Ford's Avatar
06.02.2008, 10:45 PM
When extending leads past recommended length (12" from where the Batt wires solder to t he ESC and where the wires solder to the pads on the lipo cells) you must add an extra cap of equal uF rating and voltage. Every 4" of added length, add a cap.I use a pin soldering ti to poke holes in the wires right off the PCB, insert the solder "legs", and fill with solder.
Joe Ford
Product Specialist
e-mike
e-mike's Avatar
06.02.2008, 10:57 PM
tanks,,Joe
my pack;neuenergy 2x 7,4 25c 5000mah
maxamp 2x7,4 20c 8000mah hv
maxamp 2x7,4 20c 6000mah
elite lipo 2x 7,4 4800mah 25c
hecell copper tab 4000mah 25c 2x 7,4
jhautz
jhautz's Avatar
06.04.2008, 01:47 AM
Great tip Joe. Thanks.
Is there any detrimental effect to adding extra caps even if you dont add wire length?
to make it...
or break it...
Silent...But Deadly
06.03.2008, 12:06 AM
Joe, this gets me thinking; what mods would void the warranty? Or do they all void it?
rootar
rootar's Avatar
06.03.2008, 05:59 PM
is there any benefits of making our battery and motor leads as short as possible say motor leads 3inchs total and battery leads 5 inches total??? id like the wires as short as possible to make it look nice and neat.
azjc
06.03.2008, 07:59 PM
as far as wiring goes it is best to make the wires as short as you can get away with
Sammus
Sammus's Avatar
06.03.2008, 07:55 PM
Less resistance I guess...
