What diff oils Losi 8T Brushless
gramey
gramey's Avatar
What diff oils Losi 8T Brushless - 08.09.2008, 05:19 PM
I've bought a new Losi 8T RR which I'm converting to brushless with a Teknorc V.3 kit, Neu 1515-1Y motor using an MGM 16018-3 esc and Flightpower 4S 25C 5000mah lipo's. my question is what would be the best combination of diff oils for this set up, hard packed loose topped track?
I run 5/7/3 in my nitro 8T but I think most people are going a lot higher with the B/L especially in the centre diff
Losi 8T RR - Novarossi Plus 21-5BT/ Jammin JP3 - Teknorc 8T - Neu 1515-1Y - MGM 16025-3 Z Series ESC.
jayjay283
jayjay283's Avatar
08.09.2008, 06:50 PM
im running 10/30/7 , I dont race though, more of a closed construction site anarchy derby.
FG101C
08.10.2008, 05:32 AM
7/10/5 is pretty good. 10/10/7 works well to.
Matthew_Armeni
Matthew_Armeni's Avatar
08.11.2008, 11:57 AM
I would stay with what you have first and see if you like it. A lot of the guys that run thick center fluid use motor brakes, it helps prevent unloading during braking. I run my 8T race roller with the Tekno conversion setup as it came out of the box and it feels spot on.
  Send a message via AIM to Matthew_Armeni
gramey
gramey's Avatar
08.11.2008, 04:04 PM
Thanks for the advice guy's, I shall be using the mechanical brakes as this was the main reason I went with the Tekno conversion to retain the stock brakes.
