46t spur fit losi 8?
chumanji
46t spur fit losi 8? - 08.12.2008, 03:18 AM
I got the kyosho 46t spur, but when I try to put it together, the thickness of the spur cause it to bind with one side of the motor mount. How did you guy fit that spur on?
chumanji
08.12.2008, 03:33 AM
http://www.rc-monster.com/forum/showthread.php?t=14113
Just found out someone asked the same question...
ogrfre01
08.12.2008, 04:05 AM
I had the same problem...... it ended with that i am using the stock spur.... the top plate will also not fit (atleast in my case)... this because of that the spur comes closer to the motor mount and then it rubs against the original top plate. It would be really sweet if mike would make a optional motor mount if we want to use the kyosho plastic spur.....
