Eagle Tree Systems eLogger V3 TOASTED!!!
VintageMA
VintageMA's Avatar
Eagle Tree Systems eLogger V3 TOASTED!!! - 08.22.2008, 09:24 AM
I just bought a brand new Eagle Tree Systems eLogger V3 w/Conn 100 AMP recorder from A Main the other day. Hooked it up to the pc and it looked fine. Did a quick 2-3 minute run and it was fine. Did another 2-3 minute run and now it's toasted.
I hooked it up to the USB and no signal at all. Then I smelled the burnt circuit board smell and the label side was very hot!! There's no way that I sent more than 100Amps through it from a 6S pack as the first run showed a peak of 42 Amps - wasn't even driving hard.
Wrote a note to A Main customer service so we'll so how this ends up getting resolved.
“Everyone has a right to be stupid; some people just abuse the privilege.”
kulangflow
Never Fast Enough
kulangflow's Avatar
08.22.2008, 11:43 AM
Is there any chance that you hooked up the USB cable incorrectly to the prongs on the ETree?
I did that once (I was just off one prong) and the USB power started heating up the ETree instantly. I was holding it when it happened, so I was able to unplug it before it toasted.
VintageMA
VintageMA's Avatar
08.22.2008, 12:10 PM
Ya know - that is possible because I didn't notice any heat or smell when I pulled it from the buggy - but when I plugged it into USB I got the smell and heat pretty fast.
Didn't think a USB port could produce enough power to toast something that quickly.
There are a ton of pins on the back of that thing - very easy to not put the right plug in the right place.
kulangflow
Never Fast Enough
kulangflow's Avatar
08.22.2008, 12:35 PM
I searched around a bit and it looks like USB sends 5v at 500ma.
When I did it, it got crazy hot instantly.
Somebody like BrianG could verify it.
Sammus
Sammus's Avatar
08.22.2008, 12:40 PM
I ordered my 150A from tower. Shipped 25th Jul and still hasn't turned up yet :(
IT normally takes <7 days, but something happened in customs here recently, and I havent got anything that came into the country in the first week of August....it better come thru soon!
08.22.2008, 12:41 PM
Yeah, IIRC USB spec does call for 5v @ 0.5A. Assuming the computer circuits follow the spec, that's 2.5w being dissipated on something too small to do so.
It's kinda strange though, you'd think the plug would be keyed similar to a servo cable so that if it was plugged backwards, it just wouldn't work.
08.22.2008, 12:49 PM
No the ET is a REAL pain - Nothing is keyed some connectors are verticle and others horizontal - I'd go direct to ET 1-425-614-0450 Ext 3
VintageMA
VintageMA's Avatar
08.22.2008, 12:55 PM
Thanks Arct1k - I'll give A Main through the weekend to reply and then call ET Monday if I don't hear back.
I guess it's back to the Watts-Up meter for the weekend. It's a great meter for averages and stuff but sometimes I get the feeling it's resolution just isn't fast enough and that my Amp spikes are really higher than it shows.
kulangflow
Never Fast Enough
kulangflow's Avatar
08.22.2008, 12:58 PM
Those pins are definitely the worst thing about the ETree. They easily get bent when you're driving if your install is a bit loose/weak. I wish they had a plastic cap on the pins and mounting tabs of some sort for the whole unit.
The weight of the batt/esc wires bouncing around is often stronger than the velcro I use, so it gets loose. I use it in several different vehicles and take it out to hook it up to the PC, so I' haven't been motivated to come up with a super secure mount.
It's not a HUGE deal, but it can obviously cause problems.
VintageMA
VintageMA's Avatar
08.22.2008, 01:35 PM
Well - if I can't get it replaced/repaired - I've got a $65 pair of Dean's plugs out of the whole deal.
tc3_racer_001
tc3_racer_001's Avatar
08.22.2008, 06:25 PM
hobbycity sells them for $45 or so. dont know why youd buy it for 65 elsewhere!
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
skellyo
skellyo's Avatar
08.22.2008, 07:13 PM
Not true...
http://www.hobbycity.com/hobbycity/s...er_V3_E-Logger
tc3_racer_001
08.23.2008, 04:32 AM
sorry, $49.53, still cheaper though :)
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
Sammus
Sammus's Avatar
08.23.2008, 08:45 AM
If you login, everything suddenly appears cheaper
skellyo
skellyo's Avatar
08.23.2008, 08:51 AM
Not for the Eagletree...at least not for me.
