E-Slayer Build
rckcrwlr
Where are the Rocks????
rckcrwlr's Avatar
E-Slayer Build - 09.14.2008, 11:30 AM
Well, I had to take the plunge.
Was so close to buying a Slash but was not impressed with the 2wd aspect of it.
When I saw that the slayer was based off the Revo chassis...I just had to have it...there is no better suspension geometry out there...
Under the hood is a beautiful thing...yes a 3.3 Nitro Motor on this thing...
Bought my Wife a Rock Garden :027:
rckcrwlr
rckcrwlr's Avatar
09.14.2008, 11:33 AM
OK, enough of that non-sense...
Out with the old power...
IN WITH THE NEW POWER!!!!
I would like to introduce you to.......
E-SLAYER!!!!!!!!
rckcrwlr
rckcrwlr's Avatar
09.14.2008, 11:36 AM
Now for the build...
Doing some research on here it came down to two options with this conversion; 1 Build it from scratch like I did my savage or 2 find a conversion kit to help with some of the modifying.
Going with number 1 on my Savage created a lot of headaches, wasted funds and foolish purchases. I opted for number 2.
Now came the research time...I found out that the Slayer Chassis is the Revo Platinum Chassis so any of the Revo conversions should work.
I opt'd for Tekno due to the known quality and the use of the clutch bell set up. Plus a cool t-shirt
This kit includes a 5mm flywheel/clutchbell adapter; adjustable motor mount; battery tray; radio box; ESC mount and detailed instructions.
So to start you need to remove all the Nitro stuff from the the chassis which includes:
Fuel Tank, Tubing and Mounting Post
EZ Start and Wires
Exhaust Pipe and Hanger
Engine and Mount
Left Radio Box
Throttle Linkage and Return Spring
Receiver, Switch, Receiver Battery
Right Radio Box
rckcrwlr
rckcrwlr's Avatar
09.14.2008, 11:39 AM
Now you need to remove the flywheel off the engine.
The kit comes with an adapter that puts the whole clutch assembly onto a 5mm shaft of a BL Motor...
You can then assemble the motor mount. This thing lays right in where the Nitro Engine mount set. It also gives you full adjustability for most popular BL Motors up to the length of and XL (what I am using)
It also gives you full adjustability for perfect mesh setting
Once you have that set...you are home free
Install the ESC Mount
Install the battery Tray and straps
You are pretty much done with the conversion...
trev3813
Dsm needed
trev3813's Avatar
09.14.2008, 11:38 AM
Looks great, and thanks for the info on the platinum chassis, i wanted one of those for my revo, (when ever i get one)
phatmonk
RC carbon junkie
phatmonk's Avatar
Looks great did you stay with the 2 channel traxxas transmitter and split the signal for the brake/esc?I will receive my Slayer this week with conversion parts etc.
rckcrwlr
rckcrwlr's Avatar
09.14.2008, 11:42 AM
I used a Spektrum DX3R just because I had it and am planning on racing it against those fume sniffers...
rckcrwlr
rckcrwlr's Avatar
09.14.2008, 11:44 AM
Now comes the electronics...
When you are running a nitro tranny you must use the mechanical brake and disable the ESC brake. Wiring is easy by using a "Y" Connector where the ESC and Brake Servo go in the two sides and you plug it into the Receiver Throttle Slot.
So I had this small ESC laying around so I figured I would use it on this project... :o
It is a little thing called a Mamba Monster Maxx (MMM)...check out these specs:
The only way to appreciate the size is to compare it. The first pic is the motor wire next to a servo wire. The second is a stock bullet plug and the one's that come with the MMM. These things are huge!!!!
It comes with a built in fan that when it is spooling up sounds like a turbine...
So she is all ready to go...just waiting on a 5s LiPo to get this puppy going...
rckcrwlr
rckcrwlr's Avatar
09.14.2008, 11:46 AM
Here is the combo that I am leaning to...Anything more than that will be uncontrollable with this rig... (Thanks BrianG)
The key to remember versus Nitro is that with BL it is instant speed...
Differential Ratio: 2.8461538461538463
Transmission Ratio: 1.5294117647058822
Spur Tooth Count: 36
Pinion Tooth Count: 17
Total Voltage: 18.5
Motor KV: 1668
Tire Diameter (inches): 4.6
Tire Ballooning (inches): .5
Motor coil Ω: 0.0114
Spur/Pinion Ratio: 2.12 : 1
Total Ratio: 9.21799 : 1
Tire Circumference (inches): 17.59 inches (446.86 mm)
Total Motor Speed: 30858 RPM
Vehicle Speed: 55.77 mph (89.59 km/h)
Estimated Adjusted Speed: 52 mph (83 km/h) - 8% loss
Effective KV Value: 1668
KT constant: 0.81 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
rckcrwlr
rckcrwlr's Avatar
09.14.2008, 11:48 AM
Well...bit the bullet and ordered the juice...
Thanks for the input Jason...
MaxAmps Lipo 5000HV 5S 18.5V Pack
Check out these specs:
# 5000mah Capacity
# 18.5 Volts
# 45mm X 138mm X 42mm
# 20C Constant(100 amps)
# 30C Sustained(150 amps)
# 50C Burst(250 amps)
# 565 grams
# Battery Pack comes with Hyperion Taps
# Highest performance in the industry
# Twice the capacity of NiMH for the same weight
# Plug and Play for any charger/balancer/vehicle
# We add the connectors and balancing taps for you
# Money Back Guarantee
# Normally ships within 24-48 hours
# Exceeds safety standards of the IATA
# Factory Fresh Cells within 3 weeks
# Can be recharged unlimited times per day
# Copper Tab Cells for lower resistance
09.14.2008, 11:47 AM
Looks good, trying to finish up my slayer conversion. Could you tell me what color springs it uses front and rear? Can't seem to find that info...
rckcrwlr
rckcrwlr's Avatar
09.14.2008, 11:54 AM
I am just using the stock set up...They are adjusted all the way out...I will probably preload them a little in the front to eliminate some nose diving but the rear are perfect...it handles exactly like a CORR Truck...
09.14.2008, 12:56 PM
Ok, but what color are the stock springs? They should be mainly red with little spots of color on the ends. Usually the front and rear are different colors...
Takedown
WARNING: May become violent.
Takedown's Avatar
09.14.2008, 12:01 PM
Looks like shes a speed demon for sure. Great build.
RIP- Tammy (9/14/08)
phatmonk
RC carbon junkie
phatmonk's Avatar
09.14.2008, 12:05 PM
Thanks for all the great pictures and details it helps to clarify some questions I had.I have a 1512/1.5d I will be using I was gonna use a 1515 but thats a overkill.
