Gorilla Motor Mount issues
steve050773
Gorilla Motor Mount issues - 11.13.2005, 08:14 PM
Need some opinions regarding the gorilla motor mount. I had this mount installed in the xbrace chassis for about a week and I have already bent both of the "lobes" used to attach the motor to the mount. The first was bent in a real nasty crash that I would have fully expected to bend it on, however the second bent on just a tumble. The motor is the hvmaxx and I ran it mounted in one position off from vertical.
Before ordering some more parts, do you guys think that the motor mount lobes will hold up to the hvmaxx's weight for bashing if I move the motor to the lowest possible position? Or should I save myself money/headache and just flip the differentials back and install the factory motor mount?
Thanks,
Steve
coolhandcountry
coolhandcountry's Avatar
11.13.2005, 08:55 PM
The stock is stronger for sure. I run a heavier motor than the hv and it holds. It may be weak form first bend.
Peace!
Country
Help support the
Rc-Monster
Buy here
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
11.13.2005, 11:24 PM
I use the two lobes for one motor for the larger motors
Serum
Serum's Avatar
11.14.2005, 01:41 AM
Yeah, that should do the trick. But he hasn't got a straight one anymore.. :p
Or you could use a motor holder that connects your motor with his rear to the frame.
steve050773
11.15.2005, 09:41 AM
Mike - can you clarify on how you use two?
Steve
RC-Monster Mike
Site Owner
11.15.2005, 10:50 AM
Sure. With the G-maxx motor mount, the actual part that the motor mounts to is screwed onto the center upright(the part that is attached to the chassis) with two small screws. Instead of using one, use two and a longer pair of screws. I will post a picture in a minute.
RC-Monster Mike
Site Owner
11.15.2005, 10:52 AM
here is a picture
steve050773
11.15.2005, 10:56 AM
Obviously I'm not the brightest! So how has that held up for you? No issues with the heavier motors? thanks again,
Steve
RC-Monster Mike
Site Owner
11.15.2005, 11:28 AM
This mod seriously strengthens the mount in this area. I bent a motor mount or so before going to this mod, but haven't had any trouble since doing it. The only caution I would put out there is to be careful with a motor with a 1/8" shaft. This mod could cause the pinion to be out near the end of the motor shaft(lots of leverage on the shaft), which could cause a bent or broken shaft. I have actually thought of making a custom motor mount piece to screw to the g-maxx upright, with a thicker than stock piece(yet, thinner than the double mount).
coolhandcountry
11.15.2005, 07:47 PM
Would consider making one to mount a 22 series to it or would that be a bad idea?
Peace!
Country
Help support the
Rc-Monster
Buy here
