How to wire two batteries in Series
ThomasIreton
How to wire two batteries in Series - 09.29.2008, 10:03 PM
Hello,
I was wondering if someone could please tell/show me how to make a couple adapter plugs:
1. Adapter to wire two batteries in Series.
2. Adapter to wire two batteries in parallel.
Thanks,
Thomas
jayjay283
jayjay283's Avatar
09.29.2008, 10:08 PM
series, someone else can parallel, too lazy
azjc
09.29.2008, 10:19 PM
in the long run you might as well buy a premade adapter..after buying the wire and plugs and equipment needed...as I have gotten older my time has become more important....
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
09.30.2008, 01:57 AM
parallel;
http://www.hobbycity.com/hobbycity/s...idProduct=2155
series;
http://www.hobbycity.com/hobbycity/s...idProduct=2156
for higher powered systems, I recommend thicker wires;
I use this for my MMM;
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
09.30.2008, 11:40 AM
Originally Posted by hoovhartid View Post
How hard was it to put those ridges in the deans connectors?
TDC57
TDC57's Avatar
09.30.2008, 02:32 AM
WOW Ilike the last one.. i've got the other two
Nothing!.. Hahahahaaa..
JThiessen
JThiessen's Avatar
09.30.2008, 09:11 AM
So how about a triple? All my packs are 2S2P A123's, and I was thinking last night that I might want to have the ability to run 3 packs (to get 6S A123), but then normally I would only run 4S. Can it be done with a jumper wire on the plug that isnt being used?
09.30.2008, 09:38 AM
Of course. You can have as many series or parallel packs as you want. For 3 packs in series, go here and select the correct option
JThiessen
JThiessen's Avatar
09.30.2008, 11:16 AM
I was more wondering if I could use the same harness when I only run 2 packs, and just plug a jumper across the spot where I'd normally have the third pack. Seems to me that it would work.
TexasSP
Something, anything, nothing
TexasSP's Avatar
09.30.2008, 12:14 PM
Never realized that part of your site existed. Will have to remember for future questions of this nature.
www.cubicle101.com
09.30.2008, 11:29 AM
Yup. Just use a Deans with the terminals bridged...
09.30.2008, 11:47 AM
Those are different connectors from HobbyCity IIRC. Deans-clones but with the ridges...
