BEC of the 20120 Micro
virusss
virusss's Avatar
BEC of the 20120 Micro - 11.16.2005, 07:50 AM
Hallo boys i received today my brushless setup Feigao 7xl 20120
micro controller and UBEC.I wanted to ask to you as it is made to deactivate the bec of the controller micro for being able to use the ubec external? Thanks to all
Dafni
Dafni's Avatar
11.16.2005, 08:13 AM
If you want to disable the internal BEC, just remove the black jumper. (somewhere behind the red programming jumper, maybe you'll have to remove some of the shrink)
At least this is how you do it with the Warriors, but I'm quite sure it's the same on the Micros.
virusss
virusss's Avatar
11.16.2005, 08:14 AM
hallo dafni,thanks for reply i see the red jumper but i dont see the black...
Dafni
Dafni's Avatar
11.16.2005, 08:17 AM
Like I said, it's somewhere behind the red one. YOu should "see" it through the shrink. Just remove some of the shrink.
virusss
virusss's Avatar
11.16.2005, 08:22 AM
i remove the shrink the red jumper is only jumper
virusss
virusss's Avatar
11.16.2005, 08:23 AM
ooopssss i see i see :)
thanks dafni
