A switch for 2099
Monkey
A switch for 2099 - 11.17.2005, 05:06 PM
I want to put a switch on my maxx is it ok to just put it in series with the batterys
MetalMan
MetalMan's Avatar
11.17.2005, 05:24 PM
That won't work unless the switch is rated for 100amps! Just about the best way to make a swith work would be to splice the red receiver wire (positive) and stick a switch on that (in series). This would be for if you use the BEC, as it would power down the receiver, so the controller can't get a signal. If you use an external receiver power source, then you could put a switch hooked in series with the positive wire.
Serum
Serum's Avatar
11.17.2005, 05:57 PM
No, using a switch is not an option.
The switch will add resistance. Why would you use a switch?
Monkey
11.17.2005, 05:59 PM
fed up of having to take the shell of to plug the batterys in but guess ill have to get used to it
My Cars: E-Maxx, Rustler, Lazer ZX-5 and mini LST
http://mysite.orange.co.uk/seans-rc/sean.jpg
Serum
Serum's Avatar
11.17.2005, 06:02 PM
Yeah... no other option.. Or you need to route the cables a bit different.
Dafni
Dafni's Avatar
11.18.2005, 02:18 AM
If you can find one of those lightning-rod switches, the ones Igor uses to bring dead people back to life, you know, those big levers wich throw inch long sparks, it would work :L:
Serum
Serum's Avatar
11.18.2005, 04:20 AM
You can use it as a shell too! it might need another set of shocks and a stronger BL setup.
MetalMan
MetalMan's Avatar
11.18.2005, 09:19 PM
The switch will work inline with the positive wire on the receiver connection. In fact, that's how nitro vehicles have their switches (between RX battery and RX). You would just need to keep the wires short.
Serum
Serum's Avatar
11.19.2005, 04:50 AM
Yeah, but after a run, you still need to unhook the cables, because the esc will put them dead empty.
Monkey
11.19.2005, 07:44 AM
i modified the stock swith to fit there with the stock chassis but now i have a gorill maxx there is no where easy to mount it near the Rx and like serum says id still have to take the casing off to un hook the batteries.
Serum
Serum's Avatar
11.19.2005, 08:52 AM
If you don't like that, your in the wrong hobby.. :p
Monkey
11.19.2005, 09:02 AM
i dont mind to much just thought it would be easier to have a switch and now would have been a good time to do it as my cars allready in pieces waitng for bits to arive
