Sweet mod for any serious revo racer.. truggy mud guards, done right...
stum
Sweet mod for any serious revo racer.. truggy mud guards, done right... - 10.22.2008, 09:33 PM
Ok so here is what you need...
RPM True Tracks 80562 (cheaper off fleebay)
8ight-t Mud guards LOSA1724
SportWerks Titanium 50mm hinge pins SWK9000
SportWerks 3mm e-clips SWK2292
2-zip ties
You will need to trim up the dirt sheilds to avoid contact on the inside a little bit and you will need to drill an extra hole to lace the zip tie through and drill the standard hinge pin hole a touch bigger to fit. This mod takes minutes and is AWESOME!! It is a MUST have for any serious racer iMO, manya days my revo's rear shafts and arms had 20lbs of mud caked in after a heat or main.. this really helps keep that clear and keep you in control of your truck!
PS I know I have a few holes in the pictures on the top of the mud guards.. I tried other ways of mounting first.. those are not needed, simply slide on the longer sportwerks hinge pin and zip in the other and you are good to go. I would replace the zip tie now and then to assure you don't have it give out during a race though.
Please if anyone still frequents the Traxxas site, link this over as I know others were interested in a good way to get this setup that could take a beating.
George16
Supermaxx
George16's Avatar
10.22.2008, 10:54 PM
Nice but that's old stuff. I have done it on my supermaxx trucks. I actually have the thin rubber or plastic under the lower arms too in order to protect my UE setback arms.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
stum
10.23.2008, 07:44 AM
Ya I tried rubber stuff and a lot of other mods.. this is the only one that actually holds up for any length of time.. *ie a full night of racing ;P the others just couldn't take the jumps at our track, well the hard landings from the huge jumps :)
