BL Savage Gearing
E-Traxxer
BL Savage Gearing - 11.25.2005, 12:12 AM
Right now I have my 7XL running on 18 cells with a 12 tooth pinion. I'm running 40 Series Moabs and an MBX transmission with a 51t spur gear. I'm a bit overgeared I think with this current setup, when I switch over to my 10XL should I change the gearing a bit? I was thinking that since the 10XL doesn't run as hot it will be less overgeared.. Any suggestions appreciated.
squeeforever
squeeforever's Avatar
11.25.2005, 12:30 AM
try it an just check the temps although, i think that your right. the 10xl on the same amount of cells can take a higher gearing.
Serum
Serum's Avatar
11.25.2005, 02:17 AM
What ratio is your savage with that mbx transmission?
E-Traxxer
11.25.2005, 02:22 AM
I actually don't know, but the MBX transmission's ratio is 44/14.
Serum
Serum's Avatar
11.25.2005, 02:27 AM
so a 3.14 to 1 ?
E-Traxxer
11.25.2005, 02:30 AM
I actually don't know how exactly to calculate final drive ratios, I always just gear by feel, temps, and instinct!
Serum
Serum's Avatar
11.25.2005, 04:06 AM
Just post the gears that touch eachother..
E-Traxxer
11.25.2005, 02:30 PM
Do you mean the pinion and spur? I'm running a 12 tooth pinion and 51tooth spur.
