1/8 scale buggy project
Steve Vasdekis
1/8 scale buggy project - 11.26.2005, 12:11 AM
Here is the start of my project. Still lots to do.
Steve Vasdekis
11.26.2005, 12:12 AM
Another.
rchippie
rchippie's Avatar
11.26.2005, 12:29 AM
Steve looks great so far. Is that a mugen mbx 4 or 5 ?. Have you seen mine ?. The thread is titled hippies bl mbx4.
Steve what motor is that ?.
REAL MEN RUN BRUSHLESS
camel_rc
11.26.2005, 01:52 AM
That's a nice 4 you've got there! Looks really clean.
Steve Vasdekis
11.26.2005, 07:24 AM
That is a 4. The motor is an old Aveox 1412/1.5 turn. The motor still maybe changed. Yes I have seen the hippie and I hope mine comes out as nice as yours.
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
11.26.2005, 08:49 AM
nice setup. Im not suprise if urs does. How u gunna setup ur batts? Hippi style?
~~~~~~~~RC Garage~~~~~~~~
LSP-R - Picco .26
Custom E-Revo - Warrior 9920/Feigao 9L
Nitro Revo - .18tm
  Send a message via AIM to nbcaznmaster
Sylvester
Sylvester's Avatar
11.26.2005, 09:05 AM
Speaking of batteries how many cells are you running?
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
MetalMan
MetalMan's Avatar
11.26.2005, 08:42 PM
Not bad! Would you care to share some close-ups of your motor mount? :)
Steve Vasdekis
11.26.2005, 10:54 PM
One.
Steve Vasdekis
11.26.2005, 10:55 PM
Two.
rchippie
rchippie's Avatar
11.26.2005, 11:51 PM
Steve were did you get the motor mount, & what center diff is that ?.
PS
If i can help in any way just ask.
Are you going to run lipo's or regular batts ?.
Serum
Serum's Avatar
11.27.2005, 06:18 AM
Looks great!
You really need a hardened pinion on that motor, the normal MOD1 gears will be shredded within 2 runs.
Where are you going to drop your batteries?
here is the conversion of a HB lightning Pro i did.
Steve Vasdekis
11.27.2005, 07:27 AM
Hippie, I designed it and my friend cut it with a wire for me. The diff I am not sure, but it has MBX carved into it.
Serum, where do I get the right pinion? I am either going to run a 4s4p 2500 tanic pack or a 6s4p 2000 TP pack and change out the motor.
Thanks for the compliments!
Steve
Serum
Serum's Avatar
11.27.2005, 07:40 AM
I changed the spur tp a plastic one. Mike has got all the pinions i use.
E-Traxxer
11.27.2005, 07:45 AM
I haven't had much luck finding a hardened pinion either, you should try to make an adaptor plate to mount oine of the ofna 51t plastic spurs, like hippie did.
