RC8 build
entjoles
RC8 build - 11.09.2008, 07:03 PM
here is my new project , it will have a neu 1512 2.5d and run on 4 and 5s with a Mamba Monster , mostly track duty
i will be getting the RCM chassis once available
the top plate is homemade form aluminum and painted black to blend in , also fitted the plastic piece on top to look pro , it may need to be trimmed alittle to fit a finned motor in there , but it is close for now until i get my motor
sounds like there may be enough of us electric guys to run the indoor races this winter so i had to get a buggy and ditch the e-revo
thanks for looking
the first pic is a mock up with a rx pack , my MMM wont run with out it until i send it in , the last two pics are its current stage
Steve Krug
Steve Krug's Avatar
11.09.2008, 08:18 PM
There ya go man!
I'm excited to race against your RC8 on Dec. 6!
And hey if you are still not 100% satistfied with your setup by dec. bring it up anyways and just race it for the day to work the kinks out. If you can't get your hands on a new MMM just run the reciever pack no biggy. We just need a turnout so we can use the track and prove ourselves with our electric conversions lol.
entjoles
11.09.2008, 08:24 PM
my next purchase is a motor , and some tires
but i will get what i can and be there, even if i have to run the novak motor , i just dont want to let you guys down by not showing up........
just hope it isnt a flame thrower............this motor is way to hot and the esc. fan runs alot
Steve Krug
Steve Krug's Avatar
11.09.2008, 08:53 PM
If i'm not mistaken Marco has got a 2.5D for sale? He made a thread over on RCTECH. Maybe you should check it out.
entjoles
11.09.2008, 09:59 PM
i talked to Cain and may pick up his if didnt sell it
TDC57
TDC57's Avatar
11.12.2008, 09:30 PM
Hey big guy,
looks like a great project, I have just a few questions for you, hope you don’t mind??
• What weight oil will you be using in the front, center and rear diffs?
• Please weigh it when your done, I'm really curious to see how much it weighs (thanks)
• Do you know what gearing you’ll be running it at??
• What tires are you getting ?? DB just posted up a thread on some new tires you might want to check it out.. (just and FYI)..
• Will you be using the stock shocks or going with some aftermarket ones ??
• Please post racing pictures / video when you have it..
Thanks for sharing your latest bad boy..
Nothing!.. Hahahahaaa..
entjoles
11.12.2008, 11:05 PM
i am starting with 5/10/5 in the diffs
with 4s and a 1512 2.5d i am thinking about a 17-19 t pinion , the rc8 has a 44t spur and truggy diffs
for tires i have been thinking of the proline revolver wides or aka tires (either)
for now i will run the ft shocks , with some mods , rtr caps and bladders that are cut out , and about 5mm of fuel line inside on the shafts and start with 40 wt
i cut the esc. top mount plate , the part where the esc. mounts is about half the size now , i decided to try and mount that novak motor with a 12t and it was way off
pics will come once i get a body painted , motor, and i get Mikes chassis.......no sense in wasting thread space , it will be a few weeks though
i will hopefully have some vid. of a race coming up on the 6th of Dec. , there are a few of us here that are going to go and hopefully have enough to have a electric buggy class , i will run it as is if i need to , really dont want to let any of the guys up here down , even if it goes up in flames.........the motor is a 4.5 hvmaxx motor and runs hot and the fan on the esc. runs alot as well
ill check out that tire thread , thanks
slimthelineman
slimthelineman's Avatar
11.13.2008, 12:10 AM
nice job! whats the deal with the rtr caps and cut bladders? i am really happy with the stk shocks so far.
cheesecake
11.13.2008, 12:14 AM
why the thick center diff fluid you should try it 5-5-5 with the brushless setup i love mine that way
entjoles
11.13.2008, 12:41 AM
they are supposed to be easy to rebuild?? i bought it used and i left them as is for now
i had 5/5/5 and the quick run i gave it looked like i needed something thicker in it , i ran it with the hvmaxx 4.5 motor and with punch @ 100% anything over 1/2 throttle made the ft tires light up like crazy , up to about 30 mph or so.........
i have not ran it yet with the 10k in there so well see once i get my motor
entjoles
02.13.2009, 08:49 PM
well after a long wait i finally got to order the rc-m chassis and a 2650kv motor to go with it , ill post up some pics when they get here , i am sure they will get here quick as Mike is the best
entjoles
02.20.2009, 09:01 PM
parts were here yesterday, i will get to it tonight once my beer gets cold , pics later........if i dont pass out.....
entjoles
02.21.2009, 12:29 PM
here it is , thanks to RCM for a great product , the only issue i have with this build is the motor , its very tight , the mesh is purfect but i can spin the front tires and the rears will spin as well and the motor wont move , those magnets are strong
Chassis = ***** 5 Stars
i also had to use the 44t spur , the 46t plastic i had seemed to rub , and i know the diff was a little wet when i tested the motor so i made a mess ;)
geared 14/44 on 4s for about 38.5 mph
i used the center diff plate i made as i didnt want to paint Mikes
i will also shorten the wires once i get a good soldering station
thanks again RCM, on with the pics
entjoles
02.21.2009, 12:31 PM
Gee
A Horse's Ass
Gee's Avatar
02.21.2009, 12:57 PM
Looks really nice!
