Got a Great Deal on MMM combo!
Carraig042
Got a Great Deal on MMM combo! - 11.10.2008, 01:46 PM
I just thought I would share my excitement after a dull and bad week last week.
I just pre-ordered the MMM 2200kv combo for $240 shipped! I can wait til they are finally shipped!
Time to cancel the order of the 70mm Medusa.
-Brett
skellyo
skellyo's Avatar
11.10.2008, 01:59 PM
Lemme guess...super saver member?
Dafni
Dafni's Avatar
11.12.2008, 07:40 AM
I joined that club too... but how do I find this offer?
skellyo
skellyo's Avatar
11.12.2008, 09:01 AM
It was e-mailed to me. However, it should work for all Super Saver club members. Here are the codes:
If Your Order Totals: YOU SAVE Use Ad#
$150.00 - $199.99 $20.00 016J1
$200.00 - $224.99 $30.00 016J2
$225.00 - $249.99 $35.00 016J3
$250.00 - $299.99 $50.00 016J4
$300.00 or more $60.00 016J5
XSKAPE
11.12.2008, 07:48 PM
works thanks. just ordered one cheers
Carraig042
11.10.2008, 02:10 PM
How would ever guess that, lol. Good thing I joined a few days ago.
-Brett
Carraig042
11.10.2008, 03:39 PM
BTW. What gearing do you think I should use to start with in my E-Revo using 4s?
I was thinking 20tooth pinion and 62, 65, and 68 spur gears. Do you think that will be a good place to start with. I used the speed calculator, but I am new to the electric scene.
-Brett
mikey09120
RC-Monster Stainless Steel
mikey09120's Avatar
11.10.2008, 03:47 PM
[quote=Carraig042;231359]BTW. What gearing do you think I should use to start with in my E-Revo using 4s?
-Brett[/quotei plan on using 22t pinion and a 54t spur
-mikey09120
Smashwings
Smashwings's Avatar
11.10.2008, 05:19 PM
[QUOTE=mikey09120;231362]
Hi, I'm also waiting for the Monster Combo to be released, and would like to know which is the lower Spur gear you can use with this motor (suppose similar in diameter to Neu 1515 1Y), because I also have a 20 tooth pinion from my 700HO, and I want 40mph (track race).
So I can use my 20 T pinion with a 54 T Spur ? Or the motor would collide with transmission?
Differential Ratio: 2.8461538461538463
Transmission Ratio: 1.8333333333333333
Other Ratio: 1
Spur Tooth Count: 54
Pinion Tooth Count: 20
Total Voltage: 14.8
Motor KV: 2200
Tire Diameter (inches): 5.8
Tire Ballooning (inches): 0.1
Motor Current Draw: 0
Motor coil Ω: 0.006
Spur/Pinion Ratio: 2.7 : 1
Total Ratio: 14.08846 : 1
Tire Circumference (inches): 18.85 inches (478.78 mm)
Total Motor Speed: 32560 RPM
Vehicle Speed: 41.25 mph (66.27 km/h)
Estimated Adjusted Speed: 39 mph (63 km/h) - 5% loss
Effective KV Value: 2200
KT constant: 0.61 oz-in/A
Or I should buy a 22T pinion with 56 Spur?
Other Ratio: 1
Spur Tooth Count: 58
Pinion Tooth Count: 22
Total Voltage: 14.8
Motor KV: 2200
Motor coil Ω: 0.006
Spur/Pinion Ratio: 2.64 : 1
Total Ratio: 13.75641 : 1
Vehicle Speed: 42.25 mph (67.87 km/h)
Estimated Adjusted Speed: 40 mph (64 km/h) - 6% loss
Carraig042
11.10.2008, 03:52 PM
Wow, that will be fast! 52mph! Will the setup I listed be good on the motor, esc, and batteries? Would your be better?
mikey09120
mikey09120's Avatar
11.10.2008, 03:59 PM
what batteries are you using?
do you need ideas?
-mikey09120
mikey09120
mikey09120's Avatar
11.10.2008, 04:01 PM
it should only be like 45mph. what tires are you using?
-mikey09120
Carraig042
11.10.2008, 04:05 PM
The vantage tires, bout same size as the taloon. I calculated in some balooning. (.5)
I got your calculations now.
-Brett
mikey09120
mikey09120's Avatar
11.10.2008, 04:06 PM
-Brett
oh. that explains it. what batts are you using?
-mikey09120
Carraig042
11.10.2008, 04:08 PM
Don't have any yet. I will be running 4s lipo.
I just want a good setup that will not get the electronics to hot.
-Brett
