Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
Need a spacer made
ikpthegame
Need a spacer made - 11.24.2008, 05:31 AM
hey mike im not sure if you seen my PM but I need a 5mm ID with a 6mm OD spacer made. I know that is a thin spacer and im not sure if you can make it or not but let me know.
Assistance??
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Assistance?? - 11.24.2008, 05:47 AM
I amnot sure what the application is for, but can't you just get some tubing and cut a piece to length for it? Steel, aluminum, or stainless??? Just a thought.
ikpthegame
11.24.2008, 10:39 PM
I cant find that size tube. and what do you thinks its for?
JERRY2KONE
JERRY2KONE's Avatar
11.25.2008, 12:03 AM
I have no idea what it is for, that is why I said in the last post that I have no idea what the application is for.... I was mearly saying that you could go on line and find some tubing that size and make the spacer very simply by cutting it to length. You have to decide what you want it made out of and acquire the tubing first. Then you can make the spacer you need and even make spares. It is a spacer.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
11.25.2008, 12:19 AM
IDK about the tubing idea- the smallest wall thickness I can seem to find is 0.028" or about 3/4 mm. Of course, that tubing could be milled down on a lathe to the required diameter.
No Biggy.
JERRY2KONE
JERRY2KONE's Avatar
No Biggy. - 11.25.2008, 01:01 AM
No biggy man. I wasn't trying to give you a hard time. I was just trying to make a suggestion that may give you other options, so as to avoid having to wait on Mike. We all know how busy he can be. If you have a contact for a local mill shop they may have something on hand that meets your needs, or even make something up pretty quickly and cheaply?? Just trying to think of what I might do in your situation. Hope you find what you need. Good luck with that.
What's_nitro?
11.25.2008, 02:19 AM
You might try wrapping aluminum foil around (whatever it is) in order to fill the gap.
ikpthegame
11.25.2008, 01:24 PM
it is for a motor shaft. im kinda doing a weird setup.
What's_nitro?
11.25.2008, 06:05 PM
Has Mike responded to your email yet?
Andrew32
12.05.2008, 06:16 PM
personally id take a solid piece of material and bore it out with a boring tool. Then go back and fix the OD.
but i guess you just need to find a lathe
ikpthegame
12.06.2008, 12:24 AM
ya i dont got the tools to do that with. and no mike has not gotten back to me for a while.
Busy.
JERRY2KONE
JERRY2KONE's Avatar
Busy. - 12.06.2008, 01:11 AM
I exchanged emails with him yesterday about another issue, and he is knee deep in production of something else right now. He is truly very busy and that is why you are getting so many alternative suggestions for your problem from everyone else right now. We all know how busy he is with the RCM site, the RCM store, and the RCM shop most of the time, and making a spacer falls very low on the list of priorities I am sure. Mike works on a lot of very intriquet machining projects that just cannot be done any other way, and making a spacer is something that anyone can do with common shop tools. You just have to use your imagination and come up with an alternative, or ask one of the other forum members like metalman who fabricates a lot of stuff for other members. Good luck with that.
TDC57
TDC57's Avatar
12.06.2008, 01:50 AM
Yeah you might want to PM MetalMan, or Lincpimp.
Got any pictures of your fabrication?? Maybe we the team can help recommend something if we see it?? Just a thought..
Best of luck again the fabrication is always the biggest pain but the purist joy to work out.
Have a great weekend.
P.S.
Welcome to the monster!!!..
Nothing!.. Hahahahaaa..
ikpthegame
12.06.2008, 03:47 PM
oh trust me i understand that he is a very busy person thats why i have not made a pig deal of it. for now my friend semi pro came up with a temp fix till i find someone that could do it.
