Might need help
J Lewis
Might need help - 12.26.2008, 12:39 AM
I ran my RC8E two times and this last time I notice that both the front and rear CVDs that goes from the center diff is getting hot and now the Deans connector on the battery is melting, I can't find any binding. I have a 4s, 2200, MMM in a Tekno RC8 V3, is it because of the offset of the center diff, making the CVD work alot?---Jerry
GEARS Club--Harlingen Tx
Sylvester
Sylvester's Avatar
12.26.2008, 12:43 AM
I have the same problem with the normal chassis, i guess its because of the offset center diff which causes more friction.
Id use some grease in between the dogbone and drive cup and it should cool it down some..
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
12.26.2008, 12:47 AM
Ok, you may need to use thicker diff fluid in the center, or at least check to make sure you have enough in there.
As for the deans, shorten up the wires going to the esc and the battery, and make sure you have good solid solder joints on the plug. And clean the plug too, dirty plugs are bad, mm'kay.
JeffEmbracedDC
JeffEmbracedDC's Avatar
12.29.2008, 02:36 AM
Hey, Jerry!
Yeah I would first try thickening up your center diff fluid. I'd try 10k. Some people go higher. With brushless conversions on heavy accelleration you tend to unload a lot more power to the front than you'd imagine.
And as for the deans - just try to rid the circuits of as much resistance as you can. Shorten wires as much as you can, check your joints, use clean/new plugs, etc. The less resistance the less heat there will be.
I'm leaving for Florida tomorrow. I'll miss you guys!
-Jeff
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
