what kind of body...
yourtheman
what kind of body... - 01.25.2009, 05:03 PM
i got the frame rc monster so the body stock doesnt really fit on (if somebody say yes then tell me how) and i want run my crt .5 with the wing but if i put a T4 body then i will have to remove it....
anybody got idea wich body i can fit? i hkow a B44 can fit but i would like prefer a stock body crt .5....
thx!!
bensf
01.25.2009, 05:12 PM
I use a rustler body on mine. You have to cut out the back a little bit to make it fit, but it works great. You don't need the back body clip just use the front one.
yourtheman
01.25.2009, 05:15 PM
can you put a picture of your setup here?
thx
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
01.25.2009, 11:37 PM
I used a proline desert rat made for a rusty;
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
stock length body on rc monster conversion :Tutorial
Doug Shelp
stock length body on rc monster conversion :Tutorial - 02.10.2009, 02:33 AM
Hey folks i used a pro line .5 crowd pleaser (out of production) but its stock
length
trim up the body as if for stock
dremmel the body mount hole on the rear shocktower downward and use an x1crt rear body post
get a length of 1/2 " alum. angle for the left side and shoegoo it to the right side let it set overnight then install velcro on it and the outside edge of the bat tery box and the bottom of the body and its atleast as secure as a 10th buggy body
this should work with the ofna body just fine
GREYGHOST
02.10.2009, 03:30 PM
thx!!
Most 10th scale bodies will fit with a little trimming here and there,now you are as long as a 10th scale and you have a world of bodies to choose from. Here's mine on the ofna xtended ,stock body.
ID:	6380   Click image for larger version
GREYGHOST
02.23.2009, 04:39 AM
Here's an old hpi MT 10th scale body I use for street bashing.Seems to fit perfectly,maybe I will buy a new one and cut it out to fit better,since this was just a hack job to test,but wound up being a good fit.
ID:	6470   Click image for larger version
ID:	6471   Click image for larger version
