center diff in rc8t ?'s
plettenbergs
plettenbergs's Avatar
center diff in rc8t ?'s - 02.10.2009, 12:00 PM
do you have to change gearing in center diff if you change spur gear?
i put on the 46t spur gear and had a GREAT time with the rc8t...i love this truck...it actually ran cool but after about 15 minutes it heated to 150 so i let it cool for a while and ran the Dual BL!!...GOOD TIMES!!
when i put the diff together with the new 46 gear i did not install shims...after 5-10 minutes i noticed center diff crunching a little and installed 3 small shims...it seems to be smooth now
1)is my diff beat?
2)i have several UE spider 8's...will they work and should i install one?
JeffEmbracedDC
JeffEmbracedDC's Avatar
02.13.2009, 03:36 AM
Gorgeous truck! Personally I would take the diff apart and inspect the gears for damage..
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
George16
Supermaxx
George16's Avatar
02.13.2009, 07:26 AM
1. Open it up and check the bevel gears.
2. 8 spider ofna center diffs will work.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Ryu James
Ryu James's Avatar
02.16.2009, 02:47 AM
would someone mind explaining a little more about this original question. i also have a BL RC8T and i run the 46t spur gear but i never changed a thing to my center diff. everything seems smooth and sweet. should i have changed something in the diff when i went from the stock 54t to the 46t????
Jammin SCRT10 Neu 1512 1y
George16
Supermaxx
George16's Avatar
02.16.2009, 02:49 AM
No, unless the diff bevel gears themselves are broken.
Revo with OS .18TZ
plettenbergs
02.16.2009, 12:30 PM
i had the same question RU james...i think my gears are fine...no teeth missing...might have slight wear but hard to tell...i will run it and see if the CRUNCH is gone!!
hey LITO,are the UE spider8's better than stock diff?
