lipo help
monsterbaja
monsterbaja's Avatar
lipo help - 02.15.2009, 05:15 PM
Are RHINO 3S 11,1 V - 3700 mah - 20C any good,i am planning on use a couple of them(6s 3700mah) in a E-Revo(mmm 2200kv combo)
What run time can i expect .
Thanks for all help you can give me::::::
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
02.15.2009, 06:14 PM
I don't think there's enough safety margin with a 3700mah 20c pack. The packs will most likely heat up and not last long. Also 6s is a bit much for the combo IMO. Yes it is rated to handle those RPMs but do you want to drive the truck or just watch it skidding on it's lid? IMHO to keep it driveable I would go with a 4s setup and get the biggest packs that you can stuff in the trays. Most 2s packs in the 6000mah range with a 20-25C rating fit. 4s will still get you 40+MPH yet the truck will be much more manageable. If you do decide to run 6s be prepared to gear down and destroy your body!
http://www.youtube.com/watch?v=6fgrahFNST0
There is a link to a Savage flux(same esc/motor) running 6s. You can see that all it is really good for is wheelies and skidding
monsterbaja
02.16.2009, 10:41 AM
Thanks,io do have 2 hyperion 4s 4350mah,can i paralell connect them,
(4s 8700mah)
02.16.2009, 02:39 PM
That would work fine, as stated elsewhere when you asked the first time.
