My mm is getting hot....I would like an opinion or 2 -
03.19.2009, 07:53 PM
It has been thermal-ing after only 10 min....however, I am running in very soft sand w/paddle tires on rear and 2.2 Gladiators on the front.
start power.....med.
punch control..10%
timing............ 2
lvc..................3.2 on a 3s batt.
mm esc w/ccbec
motor 1509 TeknoNeu 3300kv
stock spur w/a 17 pinion
I am not getting excessive wheel spin due to the paddles on the rear...so I am thinking it is a gearing issue..opinions?
03.19.2009, 07:56 PM
do you have a fan on it?
03.19.2009, 08:06 PM
No fan...I would like to run w/out if I can, but, I know they do help
03.19.2009, 08:08 PM
IMO....you are thermalling because you are running in sand, it will put more stress on the motor due to the loss of traction
03.19.2009, 08:11 PM
yeah the motor is maxing out.
a fan really helps the mm work with bigger motors. imo
03.19.2009, 08:15 PM
Try increasing the punch control (less initial punch). More punch (i.e. less punch control) requires more initial current.
03.19.2009, 08:16 PM
I will try that as well and see...thanks
Yeah....in sandy areas I should mount a fan to help w/temps. I like to run in sand pits behind work where there are 25' piles to climb and jump over. So, I can see that the sand w/ wheel spin will cause the prob.
What fans will mount right on...any ideas?
03.19.2009, 08:36 PM
Originally Posted by emaxxnitro
many thanks!
03.19.2009, 08:50 PM
I would try running the same size tire all the way around. I bet your center diff and motor are getting a workout with the mismatched tires...
I would also drop down a few teeth on the pinion...
03.19.2009, 09:01 PM
I left the Glads. on the front for better turning..but, obviously, it its making things worse. This weekend, I will drop a tooth or 2 and try again
I am also going to try a little thicker center diff fluid to see if that helps as well
03.19.2009, 11:31 PM
what rc is this on? have you tried using rib tires for front? they are better than glads.
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
