Help!!!!
laser_cart
Help!!!! - 04.02.2009, 01:35 PM
just got inmy lipo's for my converted slayer and hooked everything up to mmm 2200KV combo and steering works fine throttle works fine but brakes is working backwards can't get it to work right anyone know how
skellyo
skellyo's Avatar
04.02.2009, 01:39 PM
What do you mean "brakes is working backwards"?
laser_cart
04.02.2009, 01:43 PM
im still using mechanical brakes and when i give brakes the servo goes the wrong way
04.02.2009, 01:58 PM
Are you using mixing you need to probably invert that chanel
laser_cart
04.02.2009, 02:03 PM
I'm running a Y harness on channel 2 for the ESC and brake servo
04.02.2009, 02:04 PM
Sounds like you are using a y cable. Nothing you can do for that except put the linkage 180 deg from where it is now so that the lever action works in the correct direction. I had to do this with my revo.
laser_cart
04.02.2009, 02:14 PM
im using a y cable i will try that but when i hit the brakes the RED light comes on does this mean something is wrong
brushlessboy16
brushlessboy16's Avatar
04.02.2009, 02:21 PM
red light on the esc Is good, that means its going to brake.
rc4x4nut
04.02.2009, 02:25 PM
Have you tried a reversing Y harness?
laser_cart
04.02.2009, 02:49 PM
I got it working moved servo arm and HOLY CRAP what a difference BUT it sometimes twitches l
brushlessboy16
lock the trans and use motor brakes then :)
04.02.2009, 03:01 PM
.....could have just swapped red and black wires on servo.............
04.02.2009, 03:14 PM
Are you serious?
BP-Revo
BMW M Power!
BP-Revo's Avatar
04.02.2009, 03:51 PM
If you did that you would have fried the onboard electronics on the servo.
04.02.2009, 04:13 PM
Are you serious?
I was, temporary brain fart, I've been gone a while
BP-Revo is right, don't swap wires!!!!!!!!
