Thoes of you using Zippy packs what balencer are you using?
C-5Quad
Thoes of you using Zippy packs what balencer are you using? - 04.20.2009, 10:29 PM
The question says it all..........I currently have a Hyperion charger eos0606I
I have 2 zippy packs on order and am wondering where to get Hyperion 3s plugs that I can have soldered up to make an adapter for balancing...I have the jst plugs to hook up to the batteries just need Hyperion end so I don't cut and swap plugs on the lipo.
brushlessboy16
brushlessboy16's Avatar
04.20.2009, 11:05 PM
Maxamps sells the plugs, but the Align Taps that come with the zippys can be easily modified to fit with the use of an exacto knife or razor.
04.20.2009, 11:17 PM
Here ya go, just use this board with your charger : http://www.allerc.com/product_info.p...oducts_id=3159
JThiessen
JThiessen's Avatar
04.21.2009, 11:23 AM
Ditto that - I use the XH adapter with mine.
Emaxx_Quebec
Emaxx_Quebec's Avatar
04.22.2009, 12:16 PM
I charge trough a LBA10 and it work very well.
riverat1540
riverat1540's Avatar
04.22.2009, 04:07 PM
lba10 as well, works great with the mrc 989 as when charge is complete it holds constant voltage to cells for an hour , sweet feature to get the cells closely balanced without draining them any
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
04.21.2009, 12:40 AM
I use the blinky and re common sense rc lipo balancer/voltage reader...both are simple and effective ESP the common sense rc one
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
Unsullied_Spy
Unsullied_Spy's Avatar
04.23.2009, 05:24 AM
I use an LBA10 with a harness off a newer charger (integrated balancer and you just plug a little adapter into it) and I swap out the adapters for different lipos. My Zippy used the Hyperion, Maxamps, etc. adapter and I had to buy a new one to fit my E-Flite lipo. Very good balancer and the swapable adapters work very well, cleanly, and efficiently.
C-5Quad
04.23.2009, 10:09 AM
Thanks for all the replys it was a big help
