Rustler vs. Rustler
Jeremy1976
Rustler vs. Rustler - 04.23.2009, 09:57 PM
My friends Rustler seems to spool up and run better on 2s than mine. He is running the VXL with 26/83 48 pitch gearing. I am running Medusa 36-50-3300 with a MMM and 0.8 gearing 17/56. His will wheelie and the motor spools up nice. Mine will not wheelie and sounds pale in comparison with his. Am I still overgeared? I went from a 19/56 to a 17/56 and cannot really tell too much of a difference in performance. Mine on 3s acts more like his with the wheelies and stuff on 2s.
Thanks
rootar
rootar's Avatar
04.23.2009, 10:22 PM
what lipo is he running and what lipo are you running?
Jeremy1976
04.23.2009, 10:27 PM
Both similar 2s packs.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
04.23.2009, 10:39 PM
similar isn't the same! He could have a higher C rating or more mah with same C rating or just a better quality pack period. Besides all that wheelies get old anyways! Wheelies = broken parts....You can't steer when your wheels are in the air and have a tendency to hit things, at least I did. Check your esc settings, you may have the punch way up or something like that.
Jeremy1976
04.23.2009, 10:41 PM
Both Polyquest 30c 5000mah. His motor just sounds stronger like it is spinning higher RPM's.
Finnster
KillaHurtz
Finnster's Avatar
I would think you are undergeared. The medusa likes a low gear to really wake up, but it's still more of a 3s motor. Gear up quite a bit and see what happens. Remember this is a torquey 4 pole motor vs a small 2 pole VXL. They won't be the same even tho the kvs are close.
Jeremy1976
04.23.2009, 10:44 PM
I was running 19/56 before and at times my motor was getting on the hot side but ESC and Pack was nice and cool. I was going to run the 21t I got with teh 56t spur but it would not mesh properly, too tight. Maybe I will get a smaller spur and try it with the 19t and 21t and see what it does as far as temps and stuff. I would just think if I was undergeared it would be really torquey down low or am I wrong?
Finnster
KillaHurtz
Finnster's Avatar
04.24.2009, 04:24 PM
Def undergeared then. Gear up. It sounds counterintuitive, but it will work. My medusa was undergeared at first, was slow and wouldn't wheelie. Geared up a few teeth, then it was a whole 'nother motor. Fast, mega-wheelies, very impressive. The motor needs a certain amt of load before it will make alot of power. Shouldn't really get warm either.
Jeremy1976
04.24.2009, 04:52 PM
Thanks bud glad to hear that! For example today, I ran a whole 2s pack through. Temps were: ESC: 78, lipo: 108, motor: 138. Then I ran my 3s pack and temps were: ESC: 85, lipo: 98, Motor: 168.
I was keeping an eye on my temps the whole time. Disabling the punch did help some it seemed. I will now gear up to 19/56 and see. Once I get my 54t I will try that with the 19 and 21t pinion.
Thank you all for the advice. Have a nice weekend!
Always Dreamin
04.23.2009, 10:50 PM
A lot of people underestimate the power of the Vxl. i loved mine.
Jeremy1976
04.23.2009, 10:52 PM
I guess I just thought the Medusa would be a tad crazier than my buds VXL. I am kind of disappointed in it at this time. I think it is a gearing issue but I am having a hard time finding a happy setup for both 2s and 3s.
Jeremy1976
04.23.2009, 11:02 PM
My punch control is at 70%, my start power is at medium, and my timing is at 10 degrees or normal. I will probably disable the punch control all together and go test it out.
Unsullied_Spy
Unsullied_Spy's Avatar
04.23.2009, 11:06 PM
Try a 54T spur and see what happens. A MedUsa motor is much better than a Feigao They do like to be geared up, I've seen 60mm MedUsa motors pushing E-Revos past 50 MPH on 4s lipo...
Jeremy1976
04.23.2009, 11:16 PM
Yes I am running a 17t now. I also have a 19 and a 21. I will get a 54 and run it with the 21. The less gears on the spur should allow for more room to mesh it up good with the 21. I also disabled my punch. Not really sure why I had it so high at 70%.
04.23.2009, 11:25 PM
Have you ran it since you disables the punch control?
