I made a charge adapter for my spektrum radio (pics)
RUSTY XL-5
RUSTY XL-5's Avatar
I made a charge adapter for my spektrum radio (pics) - 05.01.2009, 04:07 PM
Pretty pleased with the results.
I used some 12g wire (overkill I know), a deans plug, and an unused laptop charge jack. I'm currently using some crap rechargeable AA's, but I am buying some Eneloops very soon. The adapter makes it a lot easier/convenient to charge the remote's AA's without having to deal with a mischarging wall adapter.
I will spank a nitro any day...guaranteed. :)
05.01.2009, 04:08 PM
Very nice...well done!
Me too.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Me too. - 05.01.2009, 05:59 PM
Yea I am in the middle of doing the same thing for my DX3R, but have not found a suitable plug to install on it. I was thinking of doing something very similar with a TRX plug and using it with one of my battery chargers. I already have a 5 cell 6volt nm pack for it. I really need to get off my butt and Get-er-done. Nice work.
SUPERMAXX YOUR LIFE.
05.01.2009, 07:16 PM
The RadioShack 'M' or 'N' plug works (can't remember which); just test fit one. Just be aware that the "sleeve" of the plug into the Radio is the + terminal (usually the sleeve is the - terminal).
thanks.
JERRY2KONE
JERRY2KONE's Avatar
thanks. - 05.01.2009, 09:06 PM
Yea thanks BG. I remembered that you made this point in your earlier posting. I think that is why it has taken me so long to get it done, because I am leary of making the connections wrong and frying something in the process. I will get it done soon. Thank you for watching out for us.
RUSTY XL-5
RUSTY XL-5's Avatar
05.01.2009, 09:34 PM
I wasn't too sure of the polarity (I had a good assumption) so I made sure I had the polarity right before actually putting the battery "pod" into the remote. That way I couldn't smoke anything. I dont have a volt meter, so I hooked it up to my hyperion and if the polarity was wrong (which it was) it would read "reverse voltage". All I had to do is switch the two power wires around and it works like a charm.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
05.01.2009, 06:02 PM
Nice... I'm still using alkalines in all of my Tx's.
RUSTY XL-5
RUSTY XL-5's Avatar
05.01.2009, 06:52 PM
Thanks guys, it really wasn't that hard at all. 15 minutes of prep work and 5-6 minutes of solder time.
George16
Supermaxx
George16's Avatar
05.01.2009, 07:25 PM
For those that are going to do this to a Futaba radio, keep in mind that the polarity of the charging jack in the Tx itself is reversed.
I am wary about charging my batteries while inside the Tx. I just pull out the battery tray on my Futaba radio and charge it away from the radio itself.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
05.01.2009, 11:28 PM
I just made my plug to Deans adaptor so it takes this into account. However, I had to mark the adaptor with "dx3r" to make sure I don't use it on the wrong radio. I've often thought about wiring the jack in the radio to be set up the right way, but don't want to take it apart again.
clowkoy
05.02.2009, 12:01 AM
I've done this to my Futaba 2PL-FM but I have to bypass the diode inside. One problem with this is that you cannot charge at rates higher than 1 amp or the batteries will overheat or false peak (I am using Duracell/Energizer 2500's) on my 0610iNET. I just slow-charge it with my trusty Tekin 112 at 200-250mah.
05.02.2009, 12:26 AM
I use the same cells and noticed the same thing. Since I'm not usually in a hurry, I charge at 0.5A, or use the auto-NiMH setting on my Hyperion 7i. I never drain them totally down so it usually only takes 1-1.5 hours to top them off.
Patrick
Patrick's Avatar
05.02.2009, 12:15 AM
A main has some cables made for the same thing, for anyone who doesn't want to make their own.
Single lead. http://www.amainhobbies.com/product_...ducts_id/14577
Multi adapter http://www.amainhobbies.com/product_...ducts_id/29230 This one looks pretty useful.
Foxracin
05.02.2009, 11:47 PM
If your looking for a battery you can get a real cheap lipo off ebay that works great. Its a 3 cell 2600 made by a place called Boom Racing. I gave like $24 shipped for mine and I have charged it like 3 times in 6 months and I play with one of my rc cars at least every other day. Its lasts a long time.
