Esc on fire....HW...anyelse?
gabry356
Esc on fire....HW...anyelse? - 05.12.2009, 02:12 PM
Hi I have a friend he just called me to say that his HW 80amp with 2350 kv was on fire today...and when I say on fire I don't mean that it melted or just broke...It did ignite and produced fire.... he said all was correct on set up from gear ratio to timing setting( not 1) etc...
Car was a truggy 1:8 about 5kg 1:19 gear ratio, 4s lipo.
Speaking around I heard that even novak was seen on fire....
Is it possible to make something like a list according to experience to see if some brand is more safe then others or if all of them occasionally can go as bad as fire?
Thinkgs like mamba monster, tekin can have this problem too???
Thanks
cheers
bruce750i
bruce750i's Avatar
05.12.2009, 02:22 PM
Sh&1 Happens
05.12.2009, 02:41 PM
Yes I've had 3 MM's go and they self destructed - I was left with charcoal only...
Fets burn well...
littlegiant
05.12.2009, 04:19 PM
Thanks
cheers
The 5kg truck could be too heavy for the esc. What's the timing setting? Did he play around with the punch control? What speed was the truck geared for?
gabry356
05.14.2009, 07:54 AM
gear ratio 19
punch 1
timing 15 deg
lipo hyperion 5000mah 35c 4s
cheers
superek4
superek4's Avatar
05.15.2009, 08:12 PM
gear ratio 19
punch 1
timing 15 deg
cheers
Did it burn wen d punch was set or halfway during a run? Mine was burnt immediately wen I set 0 punch. I got a replacement already
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
junkman
05.14.2009, 11:04 AM
seems the punch set at 1 sends them to a fiery death every time!
himalaya
himalaya's Avatar
05.15.2009, 02:40 AM
If the fire was lit up during a run, it's likely been a result of a de-magnet-ed motor.
A de-mag motor has nothing more than a thick short wire, shorting the ESC's outputs.
....What a Blue Sky....
timaneli
05.16.2009, 09:50 AM
most of the hobbywings esc have repair..
i repair mine without problems...
3 new mosfets and replace the internal bec and now runs like a dream even at 6s..
you are what you race!!
